goofasap wrote:
Trying to make sense of what would be the safe TT towing weight limits ; i.e. GVWR, Dry Weight, UVW, and every other weight measurement i should be considering when purchasing a TT.
(I would not be towing often but when i would it would be long distance thru mnts.
i.e. - (1-time east coast to west coast)
with this truck.
2004 Chevy Silverado, Ext.Cab, 1/2 ton, 5.3 Liter V-8, with "tow package",has a trailer brake installed, weight distribution hitch,
no transmission cooler at this time, but plan to install one)
Truck specs:
GVWR - 6,200 lbs.
GAWR Front - 3,600 lbs.
GAWR Rear - 3,686 lbs.
Combined Passengers & Cargo - 1,376 lbs.
Hitch Specs:
Max trailer carrying weight - 5,000 lbs.
Max trailer carrying weight "distribution" - 12,000 lbs.
Max tongue carrying weight - 600 lbs.
Max tongue carrying weight "distribution" - 12,000 lbs.
(when the hitch label reads "Distribution" I assume this means with a weight distribution hitch?)
And what questions should I be asking that I haven't?
Thanks so much for your advice and suggestions.
How does a truck with a "tow package" not have a transmission cooler? That should be a part of any factory tow package.
