- CopilotCompanioExplorer
FrankShore wrote:
CopilotCompanion wrote:
Can any of you guys recommend an RV show where I would be likely to see the brands mentioned in this thread? We have RV shows down here but these brands don't usually participate in our area?
Thanks,
/CC
Where are you located, so people can provide dealers near you!
Here is a Lance Dealership Locator
Lance Find Dealer Link
A Northwoods Dealer Locator
You should poke around both sites, because they sometimes have info available for upcoming RV Shows
I really liked my former Arctic Fox, but I wanted something lighter and better insulated, and more options available w/ the Lance
Good luck whatever brands you buyers choose.
Finding someone who has owned both an Arctic Fox and a Lance is like stumbling onto a blue unicorn. Fascinating observation. Good to know! - CopilotCompanioExplorer
steve-n-vicki wrote:
grand design says they are 4 season
Their RVs may be grandly designed but I couldn't get their web page to load? Will try again later, I guess. Thanks for this lead. I hadn't heard of this brand before your post. - CopilotCompanioExplorerBobNDot, thank you for takng the time to write this post. It is priceless. I have taken away many action items from this single post. Very grateful, /CC
Thanks,
/CC
Middle Tennessee. Have managed to stay away from Dealers, for the most part, thus far. I prefer to rely more upon this forum bc I think you guys are a better sounding board than a dealer. I'd like to buy used but if I can't gain the expertise to do so reliably, I'm thinking I'll buy directly from the manufacturer. It's easier to go to one RV show than to visit half a dozen manufacturers, although I may do that once I've settled on a specific unit.
Again, I'm willing to travel to the RV show. As a matter of fact, I think it will be a necessary. What about that show in Hershey, Pennsylvania? Do Lance, Northwood & Outdoors RV, Highland Ridge show there? Or am I destined for the great Northwest?
As always, thanks for feedback.
/CC - goducks10ExplorerAnother reason Lance stays warmer is that they're a lot smaller than most AF trailers. If you have a non slide Lance then you have a really small Lance. Unless you were using one of their toy haulers.
Which AF and Lance models did you use? - RollandBExplorerWe've had our Arctic Fox for almost 15 months which has been our best rig for winter camping. We started out this year camping in below freezing weather and barlely had the dual pane windows fogging up. Heated it mostly with a portable electric heater, we only used the furnace to occasionally get heat to the tanks and water lines.
- FrankShoreExplorer
Thanks,
/CC
Good luck whatever brands you buyers choose. - CopilotCompanioExplorerCan any of you guys recommend an RV show where I would be likely to see the brands mentioned in this thread? We have RV shows down here but these brands don't usually participate in our area?
Thanks,
/CC - 93Cobra2771Explorer
bobndot wrote:
What does 4 season mean ? heated tanks, extra insulation ?
4 season in Seattle, Washington is not the same as 4 season in Caribou, Maine.
I used mine in extreme conditions. I used 3 RV's for snowmobiling to -30F for 3-4 weeks at a given time.
Had to drain the water system below low single digits. Then used the rv as a dry camp at a CG with heated bath house. This is what i found through my winter RV experience (2004-2015) you can weed thru it to pick n choose what might apply to you.
BTW, my non slide Lance blew away the slide model AF as far as interior warmth as well as propane use. AF used twice as much if not more, propane.
think about a second heat source. If the furnace takes a nose dive, you will not have too much time to act to winterize it.
I carried a spare digital control board as well as a spare regulator.
I also carried MR. Heater in the single 1 lb cylinder form, up to 9k btu's. For emergency use, crack a vent or window.
If you have a plastic cover on your gas tanks or a non insulated compartment. Protect and insulate your changeover gas valve (regulator) WRAP IT in insulation. The diaphragm inside can crack if it freezes, making it useless, stopping your gas flow. You can sometimes thaw them by using a hair dryer on the warm setting to defrost it prior to cracking, if you catch it in time . The hair dryer works to thaw the dump vales as well.
Some people used DOW boards as skirting under the TT's and 5th wheels. Also, keep your batteries as warm as possible. Boondockers use AGM's inside the RV where its warm .
Non slide RV's worked best. As i said, they were much warmer, used a ton less propane (30# tank lasted 2- sometimes 3 days to keep interior 60-65F slide model ...non slide model same size rv, used 30# in a week, sometimes more with the extra elec heater)) and i never had to climb on an ice covered roof to clear off a slide in order to pull it in. (strong gust of wind nearly blew me off the ice covered roof.... once)
Think twice if you think those roll up awning covers are going be work. The snow gets blown under them, then it begins to melt because there is limited roof insulation in slideouts. What you end up is a thick sheet of ice on the slideout roof which you have to remove in order to retract it. A tad difficult to accomplish if you have an awning topper. Everyone made plywood insulated covers for them.
If you plan to use your unit in very cold (below single digits F ) temps then plan to make some mods to protect yourself.
The furnace will be working almost non-stop and it still might not be enough. Depends on how cold it is and the wind direction. Most everyone installed a second thru the wall vented heater.
IT WILL HELP if you pull in a slide at night so you are heating less volume and NOT allowing cold air to penetrate around the seals, which it did on every RV in the CG. You notice it when the temps drop below zero and the wind blows on those seals.
Test it out at home without any rv water in the system, blow out the system. Then test the rv by using bottles of water and place them in areas prone to freezing.
Such as , basements , next to water lines that touch outside walls (put pipe insulation around them as well) under cabinets, other places where you think the heater doesn't reach. See if any of those bottles freeze then take measure to move warm air to those areas. Sometimes a small computer fan will work.
You might have to add insulation on baggage doors and use foam 24"x24" tiles on the floors as insulators and interior vent covers for the 14x14 roof vents.
As westend says, the windows are important, some people cover them with bubble wrap as well.
On top of my storm windows , I made my own addition thermal insulators out of heat shrink and 2 layers of DOW board with a cut out in the center to see the outside world.
Another very cold spot is the entrance door. I covered it using a heavy duty drape on a rod .
I also had to use an elec ceramic heater in the bathroom as a second heater.
Maybe they still make a vented cat ?
vented cat heater
If you find dampness under the mattress, there is a marine product that can be placed under the mattress that allows air flow to circulate.
Hypervent
Wow, a very nice post. Good job and thanks for sharing. - coolmom42Explorer II
dewey02 wrote:
coolmom42 wrote:
Olivers are very well insulated, with heated tanks. You can only buy them from Oliver, located in Hohenwald TN. You are about 200 miles away.
Where's the insulation? :)
Under the metal seat, of course. :D
