Camper_Jeff___K
May 18, 2021Navigator
Bedlam wrote:
We typically are out twice a month with the camper and draw from the tank to keep the water fresh. We may fill from city chlorinated water or from well, but I avoid filling any water that is heavy in mineral or smell. We have not gone more than three weeks without use, so I have not treated or cleaned the fresh tank. I flush the hot water tank one or twice a year and have not seen enough build up worry about cleaning it. You can pump a vinegar dilution into your hot water tank by using the winterizing siphon and not running the tank bypass if you don't want to pickle your fresh tank.
"Pickling" the fresh tank was one of the objectives. Certainly a lot of detractors to this method but it is an experiment and I'm the one who chose to try it. Seemingly, the process worked. No smell or taste in the water now. Had hotter than my hands could stand water flowing through the entire system at 130? for 30 to 40 minutes plus ambient time afterward for as long as the water held temperature. I figure the water was scalding hot for perhaps an hour total combined with the acidity of the vinegar water solution. The heat itself in the system is a big plus for any attempt at cleaning. I rather doubt there is any significant bacteria left in the system, no more than there ever is. I've been drinking the water from the TC for a couple days now and no ill effects. I may take the TC down to the waterfront tomorrow to hang out, do some work, and bake a couple loaves of bread using the water from the fresh tank.
Next time, I may try this Purogene Water Treatment Preserver.
Hope all's well with you guys...
