ScottG
Sep 18, 2023Nomad
Unless you're certain it's held in with putty/tape, have someone hold the window from the outside when you remove the inside trim ring. Manufacturers are starting to just use foam rubber as a seal and it doesn't bond the window in like the (good) old putty did.
44,071 PostsLatest Activity: Sep 17, 2026
