45Ricochet
Jul 31, 2015Explorer
Cummins12V98 wrote:FishOnOne wrote:
Wow..... I would think by simply letting off the go pedal when the camper started to sway would have prevented this mess.
NO that will make it worse! Been there done the same thing hit the brakes and did not get the job done!
No F-ing way will I ever again tow a TT unless I have a lot more TV than one would think needed!
Troy you need to get it under control before slowing gently. Yes the rim and tire and skirting will be toast but hopefully you'll guide it to a safe location buddy. You need to first get the steering under control and the only way to do that is to speed up or your toast.
Short tube
Well on edit maybe two different events in a blow out and sway. He definitely was going to fast in the first place so maybe my tube is a different subject :B But everyone should know how to react to a blown tire on a TV.
