dodge_guy
Aug 03, 2015Explorer II
That video shows why it's not all about going out and replacing a 1/2 ton with a 3/4 ton! I'm sure that's not what the guy in the video did, but if you are having towing issues with a current TV, look at your setup first! Get weights and get the hitch adjusted. Then if you are still having some kind of problem, start thinking about a heavier duty truck!
If all you do is go out and buy a bigger truck because your current one isn't handling good, all you did was buy a bigger truck with same improperly setup hitch and trailer!
