1buda
Nov 03, 2013Explorer
TT battery
How would I check my battery is charging when hooked up to shore power?
tenbear wrote:1buda wrote:tenbear wrote:1buda wrote:
Ok the battery is at 12.5. With the battery disconnected I get nothing at the + & - wires. Took my multi meter and metered at the converter + & - poles while still hooked up to the shore power, and I get 4.3. So I guess the converter is bad? All I know that it's a 40 amp unit with glass fuses. Any suggestions on different models to replace it, with breaking the wallet?
You get 4.3 volts at one end of the wires and nothing at the other. Seems like the converter is bad but the wires don't seem to good either.
What do you mean "the wires don't seem to good either"?
I would expect the same voltage at both ends of the wires when they are not connected to anything.
