alexey75 wrote:
theoldwizard1 wrote:
Why do you think your brake shoes need to be lubed ?
I don't. I'm planning to do a service (grease, inspect brakes) in a few weeks, would like to see what I might need for this service.
With ez lube system, I don't need to grease the bearings during the reassembling (after the inspection), right?
I can grease it once I'm done, with grease gun, correct?
I will never use the EZ-Lube grease zerk because of the excessive amount of grease in the hub and the very likely chance of grease getting on the brakes. Thoroughly clean the bearings and inspect them, then grease by hand. I use the grease gun to flush the old grease out of the hole in the spindle while it is apart, then never use it again. Do it right by hand and don't depend on gimmicks like EZ-Lube.
