Lwiddis wrote:
YouTube has a number of “how to” TT brake videos. Start there IMO.
Here's one to get started.One on Bearing Repack tooalexey75 wrote:
With ez lube system, I don't need to grease the bearings during the reassembling (after the inspection), right?
I can grease it once I'm done, with grease gun, correct?
You absolutely must grease the bearings before assembling them. Never reassemble a wheel up dry.
Lynnmor wrote:
I will never use the EZ-Lube grease zerk because of the excessive amount of grease in the hub and the very likely chance of grease getting on the brakes. Thoroughly clean the bearings and inspect them, then grease by hand. I use the grease gun to flush the old grease out of the hole in the spindle while it is apart, then never use it again. Do it right by hand and don't depend on gimmicks like EZ-Lube.
Best write-up yet on EZ-Lube. That's my technique as well.
Here's a video on EZ-Lube hubs which pretty much sums up what Lynnmor describes above
