ajriding wrote:
alexey75 wrote:
ajriding wrote:
Honestly, on mine, I do nothing unless I notice an issue.
Right, about an issue... During the last summer, when I was coming to full stop (probably around 10-15 mph) the truck and the trailer were swinging (going back and forth for a few seconds). It happened probably 5-6 times during the whole season. I though the brake controller output was too high, tried to lower it, but it didn't help.
Any chance someone had the same issue or knows what might be wrong?
The brakes are not my first thought. Maybe too much weight to the rear, behind the axles???
Brakes will tend to make the trailer stop swaying, even if over applied on the trailer, or they skid, which they do quite easily depending on trailer weight. I have never seen a trailer skid, or brake hard and then sway.
Could be your truck has worn front end parts?
Usually I keep the most of the weight above the axles. I know too much weight on the rear can cause swaying. But I will keep it in mind.
I don't think it's worn, it's 2018 model with about 20K miles.
