alexey75's avatar
alexey75
TT brakes maintenance
I am looking to do a brakes maintenance next month, and looking for a ways to lift our TT (with 2 axles).
As alternative to use bottle jack (and placing a bunch of blocks under the jack), can I use tools like trailer aid plus or a few blocks under one wheel in order to remove the next wheel?
Won’t it be too much weight on one axle?
Is it a good practice?
Thanks!
  • I use a bottle jack and cribbing to do one side at a time with jackstands. In this pic there are also jackstands under the axle because I was replacing the shackle bushings and equalizers.
    If you going to pull the wheel and check the brakes, it's smart to re-grease the wheel bearings and also check the shacles and suspension parts. Many/most OEMs use very cheap components that wear out quickly.
  • It just means you will have to do the same thing four times instead of two and you will need to get the tow vehicle involved. I use a bottle jack and two jackstands and have plenty of room to adjust when the wheels are off. A cement block with a 2x on it brings the jack way up.
  • "Just drive one wheel up on blocks."
    Absolutely the easiest and safest way.
  • That is a good way to adjust the brakes. You can easily get at adjuster, when nothing is in the way. IMO, it will not be too much wt on one axle! I've used my TA plus for this on several trailers, including my FW.
    Jerry
  • jdc1's avatar
    jdc1
    Explorer II
    You'll be fine. That's how trailer owners install the spare when we get a flat. No need for a jack. Just drive one wheel up on blocks.
