therink
Nov 05, 2013Explorer
To answer your question, I am not sure which model I would choose based on quality. What are the weights? (gvwr) of the three. If you will be towing with your truck on signature, you will have payload and towing limitations to consider. It appears that 1/2 truck with 3:42 axle will limit you to trailer with a trailer gvwr of around 7000 lbs or with loaded tongue not exceeding around 700 lbs. With the 3 kids, there will be lots of cargo and passenger weight to consider.
I only mention this because I once bought too much trailer for my truck and it made towing a nightmare not to mention a safety issue. I ended up having to either sell trailer or upgrade truck (both expensive options). I ended up getting larger truck.
Good luck
Steve
Good luck
Steve
