Camper_G
Nov 05, 2013Explorer
SemperFi1991 wrote:
My truck is rated for 9600lbs so I figured I would be around 6800 to 7200 max dry weight. I estimate about 800lbs for gear, sticking to under 8100lbs. Also wondering about the best hitch for the price. The Coleman is 7264 dry, Solaire is 6825 dry and the Venture is 7260 dry.
Thanks,
Ben
Ben - In my opinion all of those rigs and the weights you mentioned is asking A LOT of a half ton pickup. I'm sure your 2011 GMC has a lot more power than the 89' Chevy Silverado with 350 had, but one of my former rigs was an 87 Wilderness Yukon, I believe that had a 6800 GVW and it worked my Chevy HARD. It really was too much trailer for the truck.
Forget about the dry weights. What is the GVWR of those rigs? That's the number you should be looking at. I would guess you will be within 1,000 lbs of the trailer GVWR, fully loaded up with food, clothing for 3 kids, you and your wife/girlfriend, ETC.
With "dry" weights that high, I bet your GVWR is going to be at or over 9-10K on those trailers, and that is too much weight for a 1/2 ton pickup, in my opinion anyway.
As far as hitches go, there are lots of good options out there. I like Reese myself, the Reese with Dual-cam Sway control is nice, as is the Equalizer hitches. Hensley Arrow is big money, but I hear lots of good things about them. If you are intent on using your current pickup with any of those rigs, I'd invest in the Hensley.
Good luck with your decision.
-Greg
