Thanks much BenK.
The 94 is quite a bit different than the 96 as my fuse box is at the bottom of the dash left of the steering wheel.
I did find the red and blue wires all wrapped up under the brake booster and the red one does have a terminal on it. They are really long, which is great.
Thought I'd run the red wire over to the battery for a direct hookup, then tap the hot wire(black?)from the Prodigy into said red wire. The Prodigy wiring diagram shows a direct hookup to the battery.
The blue will go thru the firewall direct to the Prodigy. Now just have to locate the white wire on the brake switch. Of course hook up the ground, I think I'll take it all the way to the battery also.
Was RV.net down yesterday? Couldn't get on til this morning.
