TexasChaps's avatar
TexasChaps
TT for retirement use
Hello,
I'm looking for suggestions on an RV for our retirement.
we anticipate traveling some 8 months of the year with probably 50% of our stops boondocking. ( snow and desert areas ).
My TV is a ram 2500 with CTD and I am considering a bumper pull as I have a truck bed cap and need the storage capacity. looking at other posts, I see the northwood arctic fox ( or silver fox ) might be a good choice. I would appreciate input from anyone with like experience.
I'm thinking on 30ft max for the TT and price up to $45000
thanks.
  • We like our Arctic Fox 25Y and think it could fit the bill at 30' I would suggest upgrading the couch or 2 chairs for extended use. We have the standard jack-knife and it is fine for our use now, but I wouldn't want to sit in it everyday. The bedroom/bath layout is great for two people.
  • For that kind of use, I would definitely stick with Arctic Fox, or any other Northwood brand. ORV is a close 2nd (I have one) but AF-Nash still uses better components in some areas, since the price point is slightly higher. Stuff like slideout drives and leveling jacks are just higher-end and more durable. I've had to swap out all my jacks (factory swapped the upgraded the tongue jack under warranty) and I still worry about the longevity of the Schwintek system on my slide-outs. Said slide system resulted a couple visits to the factory (they did the pickup!) and its great having their excellent warranty support, but it would have been better if those visits weren't needed.
  • I would appreciate input from anyone with like experience.
    Sounds like us... MINUS the "snow areas" unless just passing thru. That length is working out pretty good, for us over all. But not perfect. But what set up is? To big for some forest campgrounds (with tow vehicle about 60 foot) But large enough to be comfortable on long trips. We also have an older class C that is a great travelling machine but to small (for us) on longer trips. So TT has worked out great for us. Wife found trailer used, a two year old Arctic Fox, hardly used and she honed in on. Owned for 2 years now. Arctic Fox is a lot better than any other RV we've owned. Little things that are not so noticeable with Arctic Fox until you live in them awhile. Arctic Fox are heavy though. Add to whatever ad's say. Our tow rig is older (2001) 2500 CTD. So had to add a few things like air bags, bigger mirrors, and few other minor things. (A few must haves IMO) If you don't have exhaust brake, I would highly consider one. I go from Canadian border to LA and not one mountain pass have I had to worry about brakes. And a good set of gauges. Pyro gauge and trans gauge most important. And a deep trans pan, Used to have trans temp of around 210 which is OK but on long hills, temps used to creep up. Now with deep dish trans pan temp hasn't gone over 190 on steepest hills in the west and in summer. With the pyro gauge, when I pull a hill I just blend in with other traffic when gauge hits 1200 I back off a little and keep it there. Works out fine for us.
    Sounds like you're going new, if so a few options are really worth while. Keep in mind that any RV takes maintenance regardless of manufacture.
    You might want to explore. http://www.nroa2003.com/forum/
    When exploring keep in mind how many actual postings are problem compared to people making mods or self imposed problems due to lack of maintenance. I think Northwoods has a good design compared to others but they are still put together by humans, so you still have problems. One thing Northwoods does to prevent problems... every unit sold, some money goes into their profit sharing fund. But money comes out of that fund when they have to pay for mistakes. Hard to get a quality unit in todays times. Trying not to be an advertisement for them. When we were looking for a replacement RV, we found very few NW owners that had any major complaints. Many were second and third owners after owning other brands. We talked with maybe 30 or 40 owners before buying. Heard more complaints from camper owners than TT or 5th wheel owners for some reason. I am Not in love with their part process AT ALL. Takes on average 3 weeks for some model specific parts. Like a small trim piece.
    Someone else said
    Good ground clearance for the TT. Look for one where the axles can be adjusted (flipped)
    Mine rides high enough that I installed a fence post sewer tube on the metal things that hit the drive way. Never scrapped. 29 inches to top of hitch ball. Actually barley clears tailgate when I open tailgate (2 wheel drive) Not in love with TT axles but no problems yet.
    Hope this helps.
  • goducks10 wrote:
    JMHO but I'd look at http://outdoorsrvmfg.com/. They're a spin off of Northwood MFG. Their new site shows that they now include dual pane windows on all but one model. The have larger tanks than Arctic Fox. Same in house built frame. Plus they have a better warranty.
    I looked at their web site. Looks like some pretty impressive features. Even the dump valves are protected.
  • TexasChaps wrote:
    Hello,
    Only YOU (two) can really determine what kind of environment you NEED to be comfortable and happy.
    To that end, a rental or two might be an extremely good investment.....unless you have "camped" before.
    The rentals do not have to be a pull behind like you are thinking about. I'm not sure you can even rent an actual trailer like that.
    The only comment I have up front is about the word "snow" in your list of potential destinations. If you venture to a place where it goes below freezing at night, you have a whole extra bunch of things to be concerned with.....like freezing pipes and using up all your propane for heat. NOT A GOOD PLAN for most people.
  • I will second the Arctic Fox comment. I do not have one buy by cousin does and it is a very well built trailer and as solid as I have seen. It also is heavy which is probably why it feels that way. With your TV this won't be an issue.
    "Boondocking" means a lot of things to a lot of different people. If you are going to be living in it for 8 months at a time I would say get a big one, the bigger the better actually. If you plan to park in a place where you don't have hookups then I wouldn't get all worked up about clearance. My cousin's Arctic Fox has a lot of clearance, more than I like actually as I think there are 3 or 4 steps to get into the cabin.
    If you are going to drag this up mountain logging roads and out through the trees then clearance will be a big issue. I would never buy a trailer and then flip the axles unless that was all I could afford.
    Northwoods Manufacturing make a number of trailers that have cold weather advantages. Look for thermal windows and a covered insulated belly pan and ducted air. My cousin's Arctic Fox has a great AC system that keeps it cool and is very quiet.
  • My first question is have you done this before?
    If you are a boondocker and used to long weeks on the road then you know the ropes. If not it might not be as expected.
    I find my TT travel limit is about 6 weeks and my wilderness canoe camping about a week.
    I enjoy both my travel time and my time at home.
    Good luck
  • JMHO but I'd look at http://outdoorsrvmfg.com/. They're a spin off of Northwood MFG. Their new site shows that they now include dual pane windows on all but one model. The have larger tanks than Arctic Fox. Same in house built frame. Plus they have a better warranty.
  • A Few things I look for:
    A floorplan that provides space for two people to move past each other no bottlenecks.
    A Floorplan that provides comfortable seating (Recliners) and space for each of you to have some alone time just in case the weather gets bad for a few days and you're stuck inside. Cabin fevers comes on quick.
"}},"componentScriptGroups({\"componentId\":\"custom.widget.CustomFooter\"})":{"__typename":"ComponentScriptGroups","scriptGroups":{"__typename":"ComponentScriptGroupsDefinition","afterInteractive":{"__typename":"PageScriptGroupDefinition","group":"AFTER_INTERACTIVE","scriptIds":[]},"lazyOnLoad":{"__typename":"PageScriptGroupDefinition","group":"LAZY_ON_LOAD","scriptIds":[]}},"componentScripts":[]},"cachedText({\"lastModified\":\"1738256407000\",\"locale\":\"en-US\",\"namespaces\":[\"components/community/NavbarDropdownToggle\"]})":[{"__ref":"CachedAsset:text:en_US-components/community/NavbarDropdownToggle-1738256407000"}],"cachedText({\"lastModified\":\"1738256407000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/EscalatedMessageBanner\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/EscalatedMessageBanner-1738256407000"}],"cachedText({\"lastModified\":\"1738256407000\",\"locale\":\"en-US\",\"namespaces\":[\"components/users/UserLink\"]})":[{"__ref":"CachedAsset:text:en_US-components/users/UserLink-1738256407000"}],"cachedText({\"lastModified\":\"1738256407000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/users/UserRank\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/users/UserRank-1738256407000"}],"cachedText({\"lastModified\":\"1738256407000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageTime\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageTime-1738256407000"}],"cachedText({\"lastModified\":\"1738256407000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageSolvedBadge\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageSolvedBadge-1738256407000"}],"cachedText({\"lastModified\":\"1738256407000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageSubject\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageSubject-1738256407000"}],"cachedText({\"lastModified\":\"1738256407000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageBody\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageBody-1738256407000"}],"cachedText({\"lastModified\":\"1738256407000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageCustomFields\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageCustomFields-1738256407000"}],"cachedText({\"lastModified\":\"1738256407000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageReplyButton\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageReplyButton-1738256407000"}],"cachedText({\"lastModified\":\"1738256407000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/AcceptedSolutionButton\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1738256407000"}],"cachedText({\"lastModified\":\"1738256407000\",\"locale\":\"en-US\",\"namespaces\":[\"components/nodes/NodeView/NodeViewCard\"]})":[{"__ref":"CachedAsset:text:en_US-components/nodes/NodeView/NodeViewCard-1738256407000"}],"cachedText({\"lastModified\":\"1738256407000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageView/MessageViewInline\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageView/MessageViewInline-1738256407000"}],"message({\"id\":\"message:2110809\"})":{"__ref":"ForumReplyMessage:message:2110809"},"message({\"id\":\"message:2110808\"})":{"__ref":"ForumReplyMessage:message:2110808"},"message({\"id\":\"message:2110807\"})":{"__ref":"ForumReplyMessage:message:2110807"},"message({\"id\":\"message:2110806\"})":{"__ref":"ForumReplyMessage:message:2110806"},"message({\"id\":\"message:2110804\"})":{"__ref":"ForumReplyMessage:message:2110804"},"message({\"id\":\"message:2110803\"})":{"__ref":"ForumReplyMessage:message:2110803"},"message({\"id\":\"message:2110802\"})":{"__ref":"ForumReplyMessage:message:2110802"},"message({\"id\":\"message:2110801\"})":{"__ref":"ForumReplyMessage:message:2110801"},"message({\"id\":\"message:2110805\"})":{"__ref":"ForumReplyMessage:message:2110805"},"cachedText({\"lastModified\":\"1738256407000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/users/UserAvatar\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1738256407000"}],"cachedText({\"lastModified\":\"1738256407000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/ranks/UserRankLabel\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1738256407000"}],"cachedText({\"lastModified\":\"1738256407000\",\"locale\":\"en-US\",\"namespaces\":[\"components/nodes/NodeTopicsCount\"]})":[{"__ref":"CachedAsset:text:en_US-components/nodes/NodeTopicsCount-1738256407000"}],"cachedText({\"lastModified\":\"1738256407000\",\"locale\":\"en-US\",\"namespaces\":[\"components/nodes/NodeLatestActivityTime\"]})":[{"__ref":"CachedAsset:text:en_US-components/nodes/NodeLatestActivityTime-1738256407000"}]},"CachedAsset:pages-1739279030048":{"__typename":"CachedAsset","id":"pages-1739279030048","value":[{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"BlogViewAllPostsPage","type":"BLOG","urlPath":"/category/:categoryId/blog/:boardId/all-posts/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"CasePortalPage","type":"CASE_PORTAL","urlPath":"/caseportal","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"CreateGroupHubPage","type":"GROUP_HUB","urlPath":"/groups/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"CaseViewPage","type":"CASE_DETAILS","urlPath":"/case/:caseId/:caseNumber","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"InboxPage","type":"COMMUNITY","urlPath":"/inbox","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"HelpFAQPage","type":"COMMUNITY","urlPath":"/help","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"IdeaMessagePage","type":"IDEA_POST","urlPath":"/idea/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"IdeaViewAllIdeasPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId/all-ideas/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"LoginPage","type":"USER","urlPath":"/signin","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"BlogPostPage","type":"BLOG","urlPath":"/category/:categoryId/blogs/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"ThemeEditorPage","type":"COMMUNITY","urlPath":"/designer/themes","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"TkbViewAllArticlesPage","type":"TKB","urlPath":"/category/:categoryId/kb/:boardId/all-articles/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"OccasionEditPage","type":"EVENT","urlPath":"/event/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"OAuthAuthorizationAllowPage","type":"USER","urlPath":"/auth/authorize/allow","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"PageEditorPage","type":"COMMUNITY","urlPath":"/designer/pages","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"PostPage","type":"COMMUNITY","urlPath":"/category/:categoryId/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"ForumBoardPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"TkbBoardPage","type":"TKB","urlPath":"/category/:categoryId/kb/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"EventPostPage","type":"EVENT","urlPath":"/category/:categoryId/events/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"UserBadgesPage","type":"COMMUNITY","urlPath":"/users/:login/:userId/badges","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"GroupHubMembershipAction","type":"GROUP_HUB","urlPath":"/membership/join/:nodeId/:membershipType","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"MaintenancePage","type":"COMMUNITY","urlPath":"/maintenance","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"IdeaReplyPage","type":"IDEA_REPLY","urlPath":"/idea/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"UserSettingsPage","type":"USER","urlPath":"/mysettings/:userSettingsTab","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"GroupHubsPage","type":"GROUP_HUB","urlPath":"/groups","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"ForumPostPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"OccasionRsvpActionPage","type":"OCCASION","urlPath":"/event/:boardId/:messageSubject/:messageId/rsvp/:responseType","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"VerifyUserEmailPage","type":"USER","urlPath":"/verifyemail/:userId/:verifyEmailToken","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"AllOccasionsPage","type":"OCCASION","urlPath":"/category/:categoryId/events/:boardId/all-events/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"EventBoardPage","type":"EVENT","urlPath":"/category/:categoryId/events/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"TkbReplyPage","type":"TKB_REPLY","urlPath":"/kb/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"IdeaBoardPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"CommunityGuideLinesPage","type":"COMMUNITY","urlPath":"/communityguidelines","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"CaseCreatePage","type":"SALESFORCE_CASE_CREATION","urlPath":"/caseportal/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"TkbEditPage","type":"TKB","urlPath":"/kb/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"ForgotPasswordPage","type":"USER","urlPath":"/forgotpassword","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"IdeaEditPage","type":"IDEA","urlPath":"/idea/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"TagPage","type":"COMMUNITY","urlPath":"/tag/:tagName","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"BlogBoardPage","type":"BLOG","urlPath":"/category/:categoryId/blog/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"OccasionMessagePage","type":"OCCASION_TOPIC","urlPath":"/event/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"ManageContentPage","type":"COMMUNITY","urlPath":"/managecontent","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"ClosedMembershipNodeNonMembersPage","type":"GROUP_HUB","urlPath":"/closedgroup/:groupHubId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"CommunityPage","type":"COMMUNITY","urlPath":"/","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"ForumMessagePage","type":"FORUM_TOPIC","urlPath":"/discussions/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"IdeaPostPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"BlogMessagePage","type":"BLOG_ARTICLE","urlPath":"/blog/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"RegistrationPage","type":"USER","urlPath":"/register","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"EditGroupHubPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"ForumEditPage","type":"FORUM","urlPath":"/discussions/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"ResetPasswordPage","type":"USER","urlPath":"/resetpassword/:userId/:resetPasswordToken","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"TkbMessagePage","type":"TKB_ARTICLE","urlPath":"/kb/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"BlogEditPage","type":"BLOG","urlPath":"/blog/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"ManageUsersPage","type":"USER","urlPath":"/users/manage/:tab?/:manageUsersTab?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"ForumReplyPage","type":"FORUM_REPLY","urlPath":"/discussions/:boardId/:messageSubject/:messageId/replies/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"PrivacyPolicyPage","type":"COMMUNITY","urlPath":"/privacypolicy","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"NotificationPage","type":"COMMUNITY","urlPath":"/notifications","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"UserPage","type":"USER","urlPath":"/users/:login/:userId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"OccasionReplyPage","type":"OCCASION_REPLY","urlPath":"/event/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"ManageMembersPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/manage/:tab?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"SearchResultsPage","type":"COMMUNITY","urlPath":"/search","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"BlogReplyPage","type":"BLOG_REPLY","urlPath":"/blog/:boardId/:messageSubject/:messageId/replies/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"GroupHubPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"TermsOfServicePage","type":"COMMUNITY","urlPath":"/termsofservice","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"CategoryPage","type":"CATEGORY","urlPath":"/category/:categoryId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"ForumViewAllTopicsPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId/all-topics/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"TkbPostPage","type":"TKB","urlPath":"/category/:categoryId/kbs/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1739279030048,"localOverride":null,"page":{"id":"GroupHubPostPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"}],"localOverride":false},"CachedAsset:text:en_US-components/context/AppContext/AppContextProvider-0":{"__typename":"CachedAsset","id":"text:en_US-components/context/AppContext/AppContextProvider-0","value":{"noCommunity":"Cannot find community","noUser":"Cannot find current user","noNode":"Cannot find node with id {nodeId}","noMessage":"Cannot find message with id {messageId}"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-0":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-0","value":{"title":"Loading..."},"localOverride":false},"User:user:-1":{"__typename":"User","id":"user:-1","uid":-1,"login":"Community Alumni","email":"","avatar":null,"rank":null,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":"ANONYMOUS","registrationTime":null,"confirmEmailStatus":false,"registrationAccessLevel":"VIEW","ssoRegistrationFields":[]},"ssoId":null,"profileSettings":{"__typename":"ProfileSettings","dateDisplayStyle":{"__typename":"InheritableStringSettingWithPossibleValues","key":"layout.friendly_dates_enabled","value":"false","localValue":"true","possibleValues":["true","false"]},"dateDisplayFormat":{"__typename":"InheritableStringSetting","key":"layout.format_pattern_date","value":"MMM-dd-yyyy","localValue":"MM-dd-yyyy"},"language":{"__typename":"InheritableStringSettingWithPossibleValues","key":"profile.language","value":"en-US","localValue":"en","possibleValues":["en-US"]}},"deleted":false},"Theme:customTheme1":{"__typename":"Theme","id":"customTheme1"},"GroupHub:grouphub:TravelTrailer":{"__typename":"GroupHub","id":"grouphub:TravelTrailer","entityType":"GROUP_HUB","displayId":"TravelTrailer","nodeType":"grouphub","depth":2,"title":"Travel Trailer Group","shortTitle":"Travel Trailer Group","parent":{"__ref":"Category:category:TRAVELCENTER"}},"Category:category:top":{"__typename":"Category","id":"category:top","displayId":"top","nodeType":"category","depth":0,"title":"Top","entityType":"CATEGORY","shortTitle":"Top"},"Category:category:TRAVELCENTER":{"__typename":"Category","id":"category:TRAVELCENTER","displayId":"TRAVELCENTER","nodeType":"category","depth":1,"parent":{"__ref":"Category:category:top"},"title":"Groups","entityType":"CATEGORY","shortTitle":"Groups","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:TravelTrailerforum-board":{"__typename":"Forum","id":"board:TravelTrailerforum-board","entityType":"FORUM","displayId":"TravelTrailerforum-board","nodeType":"board","depth":3,"conversationStyle":"FORUM","title":"Travel Trailer Group","description":"","avatar":null,"profileSettings":{"__typename":"ProfileSettings","language":null},"parent":{"__ref":"GroupHub:grouphub:TravelTrailer"},"ancestors":{"__typename":"CoreNodeConnection","edges":[{"__typename":"CoreNodeEdge","node":{"__ref":"Community:community:feyqc97479"}},{"__typename":"CoreNodeEdge","node":{"__ref":"Category:category:TRAVELCENTER"}},{"__typename":"CoreNodeEdge","node":{"__ref":"GroupHub:grouphub:TravelTrailer"}}]},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"boardPolicies":{"__typename":"BoardPolicies","canPublishArticleOnCreate":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.policy_can_publish_on_create_workflow_action.accessDenied","key":"error.lithium.policies.forums.policy_can_publish_on_create_workflow_action.accessDenied","args":[]}}},"shortTitle":"Forum","repliesProperties":{"__typename":"RepliesProperties","sortOrder":"REVERSE_PUBLISH_TIME","repliesFormat":"threaded"},"topicsCount":44026,"messageActivity":{"__typename":"MessageActivity","corePropertyChangeTime":"2025-02-24T08:13:54.631-08:00"},"eventPath":"grouphub:TravelTrailer/category:TRAVELCENTER/community:feyqc97479board:TravelTrailerforum-board/","tagProperties":{"__typename":"TagNodeProperties","tagsEnabled":{"__typename":"PolicyResult","failureReason":null}},"requireTags":false,"tagType":"FREEFORM_ONLY"},"Rank:rank:42":{"__typename":"Rank","id":"rank:42","position":35,"name":"Explorer","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:208219":{"__typename":"User","id":"user:208219","uid":208219,"login":"TexasChaps","deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-4.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"email":"","messagesCount":176,"biography":null,"topicsCount":5,"kudosReceivedCount":0,"kudosGivenCount":0,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2013-06-25T07:42:07.000-07:00","confirmEmailStatus":null},"followersCount":null,"solutionsCount":0},"ForumTopicMessage:message:2110800":{"__typename":"ForumTopicMessage","uid":2110800,"subject":"TT for retirement use","id":"message:2110800","revisionNum":1,"repliesCount":19,"author":{"__ref":"User:user:208219"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TravelTrailerforum-board"},"conversation":{"__ref":"Conversation:conversation:2110800"},"readOnly":false,"editFrozen":false,"moderationData":{"__ref":"ModerationData:moderation_data:2110800"},"body":"Hello,
thanks.","body@stringLength":"572","rawBody":"Hello,
thanks.","kudosSumWeight":0,"postTime":"2016-01-26T06:12:56.000-08:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"tags":{"__typename":"TagConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:2110800_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":5047},"visibilityScope":"PUBLIC","canonicalUrl":null,"seoTitle":null,"seoDescription":null,"isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"archivalData":null,"searchSnippet":"Hello, I'm looking for suggestions on an RV for our retirement. we anticipate traveling some 8 months of the year with probably 50% of our stops boondocking. ( snow and desert areas ). My TV i...","replies":{"__typename":"MessageConnection","edges":[{"__typename":"MessageEdge","cursor":"MjUuMXwyLjF8aXwxMHwzOTowfGludCwyMTEwODE5LDIxMTA4MDk","node":{"__ref":"ForumReplyMessage:message:2110809"}},{"__typename":"MessageEdge","cursor":"MjUuMXwyLjF8aXwxMHwzOTowfGludCwyMTEwODE5LDIxMTA4MDg","node":{"__ref":"ForumReplyMessage:message:2110808"}},{"__typename":"MessageEdge","cursor":"MjUuMXwyLjF8aXwxMHwzOTowfGludCwyMTEwODE5LDIxMTA4MDc","node":{"__ref":"ForumReplyMessage:message:2110807"}},{"__typename":"MessageEdge","cursor":"MjUuMXwyLjF8aXwxMHwzOTowfGludCwyMTEwODE5LDIxMTA4MDY","node":{"__ref":"ForumReplyMessage:message:2110806"}},{"__typename":"MessageEdge","cursor":"MjUuMXwyLjF8aXwxMHwzOTowfGludCwyMTEwODE5LDIxMTA4MDU","node":{"__ref":"ForumReplyMessage:message:2110805"}},{"__typename":"MessageEdge","cursor":"MjUuMXwyLjF8aXwxMHwzOTowfGludCwyMTEwODE5LDIxMTA4MDQ","node":{"__ref":"ForumReplyMessage:message:2110804"}},{"__typename":"MessageEdge","cursor":"MjUuMXwyLjF8aXwxMHwzOTowfGludCwyMTEwODE5LDIxMTA4MDM","node":{"__ref":"ForumReplyMessage:message:2110803"}},{"__typename":"MessageEdge","cursor":"MjUuMXwyLjF8aXwxMHwzOTowfGludCwyMTEwODE5LDIxMTA4MDI","node":{"__ref":"ForumReplyMessage:message:2110802"}},{"__typename":"MessageEdge","cursor":"MjUuMXwyLjF8aXwxMHwzOTowfGludCwyMTEwODE5LDIxMTA4MDE","node":{"__ref":"ForumReplyMessage:message:2110801"}}],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":true,"startCursor":"MjUuMXwyLjF8aXwxMHwzOTowfGludCwyMTEwODE5LDIxMTA4MDk"}},"customFields":[]},"Conversation:conversation:2110800":{"__typename":"Conversation","id":"conversation:2110800","solved":false,"topic":{"__ref":"ForumTopicMessage:message:2110800"},"lastPostingActivityTime":"2016-02-21T15:13:58.000-08:00","lastPostTime":"2016-02-21T15:13:58.000-08:00","unreadReplyCount":19,"isSubscribed":false},"ModerationData:moderation_data:2110800":{"__typename":"ModerationData","id":"moderation_data:2110800","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"Revision:revision:2110800_1":{"__typename":"Revision","id":"revision:2110800_1","lastEditTime":"2016-01-26T06:12:56.000-08:00"},"CachedAsset:theme:customTheme1-1739279029693":{"__typename":"CachedAsset","id":"theme:customTheme1-1739279029693","value":{"id":"customTheme1","animation":{"fast":"150ms","normal":"250ms","slow":"500ms","slowest":"750ms","function":"cubic-bezier(0.07, 0.91, 0.51, 1)","__typename":"AnimationThemeSettings"},"avatar":{"borderRadius":"50%","collections":["custom"],"__typename":"AvatarThemeSettings"},"basics":{"browserIcon":{"imageAssetName":"RGB-GoodSam-Emblem-TM-Solid-SignageGreen-1709848693343.png","imageLastModified":"1709848695145","__typename":"ThemeAsset"},"customerLogo":{"imageAssetName":"4C-GoodSam-Horiz-TM_SignageGreen-1709842742388.png","imageLastModified":"1709842744704","__typename":"ThemeAsset"},"maximumWidthOfPageContent":"1250px","oneColumnNarrowWidth":"800px","gridGutterWidthMd":"30px","gridGutterWidthXs":"10px","pageWidthStyle":"WIDTH_OF_BROWSER","__typename":"BasicsThemeSettings"},"buttons":{"borderRadiusSm":"4px","borderRadius":"4px","borderRadiusLg":"4px","paddingY":"5px","paddingYLg":"7px","paddingYHero":"var(--lia-bs-btn-padding-y-lg)","paddingX":"12px","paddingXLg":"16px","paddingXHero":"60px","fontStyle":"NORMAL","fontWeight":"400","textTransform":"NONE","disabledOpacity":0.5,"primaryTextColor":"var(--lia-bs-white)","primaryTextHoverColor":"var(--lia-bs-white)","primaryTextActiveColor":"var(--lia-bs-white)","primaryBgColor":"var(--lia-bs-primary)","primaryBgHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.85))","primaryBgActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.7))","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","primaryBorderActive":"1px solid transparent","primaryBorderFocus":"1px solid var(--lia-bs-white)","primaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","secondaryTextColor":"var(--lia-bs-body-color)","secondaryTextHoverColor":"hsl(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), calc(var(--lia-bs-body-color-l) * 0.95))","secondaryTextActiveColor":"hsl(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), calc(var(--lia-bs-body-color-l) * 0.9))","secondaryBgColor":"var(--lia-bs-gray-300)","secondaryBgHoverColor":"hsl(var(--lia-bs-gray-300-h), var(--lia-bs-gray-300-s), calc(var(--lia-bs-gray-300-l) * 0.96))","secondaryBgActiveColor":"hsl(var(--lia-bs-gray-300-h), var(--lia-bs-gray-300-s), calc(var(--lia-bs-gray-300-l) * 0.92))","secondaryBorder":"1px solid transparent","secondaryBorderHover":"1px solid transparent","secondaryBorderActive":"1px solid transparent","secondaryBorderFocus":"1px solid transparent","secondaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","tertiaryTextColor":"var(--lia-bs-body-color)","tertiaryTextHoverColor":"hsl(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), calc(var(--lia-bs-body-color-l) * 0.95))","tertiaryTextActiveColor":"hsl(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), calc(var(--lia-bs-body-color-l) * 0.9))","tertiaryBgColor":"transparent","tertiaryBgHoverColor":"transparent","tertiaryBgActiveColor":"hsla(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), var(--lia-bs-body-color-l), 0.04)","tertiaryBorder":"1px solid transparent","tertiaryBorderHover":"1px solid hsla(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), var(--lia-bs-body-color-l), 0.08)","tertiaryBorderActive":"1px solid transparent","tertiaryBorderFocus":"1px solid transparent","tertiaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","destructiveTextColor":"var(--lia-bs-white)","destructiveTextHoverColor":"var(--lia-bs-white)","destructiveTextActiveColor":"var(--lia-bs-white)","destructiveBgColor":"var(--lia-bs-danger)","destructiveBgHoverColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.85))","destructiveBgActiveColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.7))","destructiveBorder":"1px solid transparent","destructiveBorderHover":"1px solid transparent","destructiveBorderActive":"1px solid transparent","destructiveBorderFocus":"1px solid transparent","destructiveBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","__typename":"ButtonsThemeSettings"},"border":{"color":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","mainContent":"LIGHT","sideContent":"NONE","radiusSm":"3px","radius":"5px","radiusLg":"9px","radius50":"100vw","__typename":"BorderThemeSettings"},"boxShadow":{"xs":"0 0 0 1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08), 0 3px 0 -1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08)","sm":"0 2px 4px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.06)","md":"0 5px 15px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.15)","lg":"0 10px 30px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.15)","__typename":"BoxShadowThemeSettings"},"cards":{"bgColor":"var(--lia-panel-bg-color)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":"var(--lia-box-shadow-xs)","__typename":"CardsThemeSettings"},"chip":{"maxWidth":"300px","height":"30px","__typename":"ChipThemeSettings"},"coreTypes":{"defaultMessageLinkColor":"var(--lia-bs-link-color)","defaultMessageLinkDecoration":"none","defaultMessageLinkFontStyle":"NORMAL","defaultMessageLinkFontWeight":"400","defaultMessageFontStyle":"NORMAL","defaultMessageFontWeight":"400","forumColor":"#23410A","forumFontFamily":"var(--lia-bs-font-family-base)","forumFontWeight":"var(--lia-default-message-font-weight)","forumLineHeight":"var(--lia-bs-line-height-base)","forumFontStyle":"var(--lia-default-message-font-style)","forumMessageLinkColor":"var(--lia-default-message-link-color)","forumMessageLinkDecoration":"var(--lia-default-message-link-decoration)","forumMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","forumMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","forumSolvedColor":"#23410A","blogColor":"#D6D6CE","blogFontFamily":"var(--lia-bs-font-family-base)","blogFontWeight":"var(--lia-default-message-font-weight)","blogLineHeight":"1.75","blogFontStyle":"var(--lia-default-message-font-style)","blogMessageLinkColor":"var(--lia-default-message-link-color)","blogMessageLinkDecoration":"var(--lia-default-message-link-decoration)","blogMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","blogMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","tkbColor":"#C7B197","tkbFontFamily":"var(--lia-bs-font-family-base)","tkbFontWeight":"var(--lia-default-message-font-weight)","tkbLineHeight":"1.75","tkbFontStyle":"var(--lia-default-message-font-style)","tkbMessageLinkColor":"var(--lia-default-message-link-color)","tkbMessageLinkDecoration":"var(--lia-default-message-link-decoration)","tkbMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","tkbMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaColor":"#4099E2","qandaFontFamily":"var(--lia-bs-font-family-base)","qandaFontWeight":"var(--lia-default-message-font-weight)","qandaLineHeight":"var(--lia-bs-line-height-base)","qandaFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkColor":"var(--lia-default-message-link-color)","qandaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","qandaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaSolvedColor":"#3FA023","ideaColor":"#FF8000","ideaFontFamily":"var(--lia-bs-font-family-base)","ideaFontWeight":"var(--lia-default-message-font-weight)","ideaLineHeight":"var(--lia-bs-line-height-base)","ideaFontStyle":"var(--lia-default-message-font-style)","ideaMessageLinkColor":"var(--lia-default-message-link-color)","ideaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","ideaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","ideaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","contestColor":"#FCC845","contestFontFamily":"var(--lia-bs-font-family-base)","contestFontWeight":"var(--lia-default-message-font-weight)","contestLineHeight":"var(--lia-bs-line-height-base)","contestFontStyle":"var(--lia-default-message-link-font-style)","contestMessageLinkColor":"var(--lia-default-message-link-color)","contestMessageLinkDecoration":"var(--lia-default-message-link-decoration)","contestMessageLinkFontStyle":"ITALIC","contestMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","occasionColor":"#CBCBCB","occasionFontFamily":"var(--lia-bs-font-family-base)","occasionFontWeight":"var(--lia-default-message-font-weight)","occasionLineHeight":"var(--lia-bs-line-height-base)","occasionFontStyle":"var(--lia-default-message-font-style)","occasionMessageLinkColor":"var(--lia-default-message-link-color)","occasionMessageLinkDecoration":"var(--lia-default-message-link-decoration)","occasionMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","occasionMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","grouphubColor":"#232323","categoryColor":"#949494","communityColor":"#FFFFFF","productColor":"#949494","__typename":"CoreTypesThemeSettings"},"colors":{"black":"#000000","white":"#FFFFFF","gray100":"#F7F7F7","gray200":"#F7F7F7","gray300":"#E8E8E8","gray400":"#D9D9D9","gray500":"#CCCCCC","gray600":"#949494","gray700":"#707070","gray800":"#545454","gray900":"#333333","dark":"#545454","light":"#F7F7F7","primary":"#23410A","secondary":"#333333","bodyText":"#232323","bodyBg":"#FFFFFF","info":"#23410A","success":"#39842B","warning":"#C3FF49","danger":"#C30B24","alertSystem":"#FF6600","textMuted":"#707070","highlight":"#FFFCAD","outline":"var(--lia-bs-primary)","custom":["#C7B197","#D6D6CE","#CBCBCB","#C3FF49","#C30B24","#F2EDEB"],"__typename":"ColorsThemeSettings"},"divider":{"size":"3px","marginLeft":"4px","marginRight":"4px","borderRadius":"50%","bgColor":"var(--lia-bs-gray-600)","bgColorActive":"var(--lia-bs-gray-600)","__typename":"DividerThemeSettings"},"dropdown":{"fontSize":"var(--lia-bs-font-size-sm)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius-sm)","dividerBg":"var(--lia-bs-gray-300)","itemPaddingY":"5px","itemPaddingX":"20px","headerColor":"var(--lia-bs-gray-700)","__typename":"DropdownThemeSettings"},"email":{"link":{"color":"#0069D4","hoverColor":"#0061c2","decoration":"none","hoverDecoration":"underline","__typename":"EmailLinkSettings"},"border":{"color":"#e4e4e4","__typename":"EmailBorderSettings"},"buttons":{"borderRadiusLg":"5px","paddingXLg":"16px","paddingYLg":"7px","fontWeight":"700","primaryTextColor":"#ffffff","primaryTextHoverColor":"#ffffff","primaryBgColor":"#0069D4","primaryBgHoverColor":"#005cb8","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","__typename":"EmailButtonsSettings"},"panel":{"borderRadius":"5px","borderColor":"#e4e4e4","__typename":"EmailPanelSettings"},"__typename":"EmailThemeSettings"},"emoji":{"skinToneDefault":"#ffcd43","skinToneLight":"#fae3c5","skinToneMediumLight":"#e2cfa5","skinToneMedium":"#daa478","skinToneMediumDark":"#a78058","skinToneDark":"#5e4d43","__typename":"EmojiThemeSettings"},"heading":{"color":"var(--lia-bs-body-color)","fontFamily":"Aeonik Pro","fontStyle":"NORMAL","fontWeight":"700","h1FontSize":"56px","h2FontSize":"45px","h3FontSize":"38px","h4FontSize":"32px","h5FontSize":"26px","h6FontSize":"24px","lineHeight":"1.3","subHeaderFontSize":"18px","subHeaderFontWeight":"500","h1LetterSpacing":"normal","h2LetterSpacing":"normal","h3LetterSpacing":"normal","h4LetterSpacing":"normal","h5LetterSpacing":"normal","h6LetterSpacing":"normal","subHeaderLetterSpacing":"2px","h1FontWeight":"var(--lia-bs-headings-font-weight)","h2FontWeight":"var(--lia-bs-headings-font-weight)","h3FontWeight":"var(--lia-bs-headings-font-weight)","h4FontWeight":"var(--lia-bs-headings-font-weight)","h5FontWeight":"var(--lia-bs-headings-font-weight)","h6FontWeight":"var(--lia-bs-headings-font-weight)","__typename":"HeadingThemeSettings"},"icons":{"size10":"10px","size12":"12px","size14":"14px","size16":"16px","size20":"20px","size24":"24px","size30":"30px","size40":"40px","size50":"50px","size60":"60px","size80":"80px","size120":"120px","size160":"160px","__typename":"IconsThemeSettings"},"imagePreview":{"bgColor":"var(--lia-bs-gray-900)","titleColor":"var(--lia-bs-white)","controlColor":"var(--lia-bs-white)","controlBgColor":"var(--lia-bs-gray-800)","__typename":"ImagePreviewThemeSettings"},"input":{"borderColor":"var(--lia-bs-gray-600)","disabledColor":"var(--lia-bs-gray-600)","focusBorderColor":"var(--lia-bs-primary)","labelMarginBottom":"10px","btnFontSize":"var(--lia-bs-font-size-sm)","focusBoxShadow":"0 0 0 3px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","checkLabelMarginBottom":"2px","checkboxBorderRadius":"3px","borderRadiusSm":"var(--lia-bs-border-radius-sm)","borderRadius":"var(--lia-bs-border-radius)","borderRadiusLg":"var(--lia-bs-border-radius-lg)","formTextMarginTop":"4px","textAreaBorderRadius":"var(--lia-bs-border-radius)","activeFillColor":"var(--lia-bs-primary)","__typename":"InputThemeSettings"},"loading":{"dotDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.2)","dotLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.5)","barDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.06)","barLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.4)","__typename":"LoadingThemeSettings"},"link":{"color":"var(--lia-bs-primary)","hoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) - 10%))","decoration":"none","hoverDecoration":"underline","__typename":"LinkThemeSettings"},"listGroup":{"itemPaddingY":"15px","itemPaddingX":"15px","borderColor":"var(--lia-bs-gray-300)","__typename":"ListGroupThemeSettings"},"modal":{"contentTextColor":"var(--lia-bs-body-color)","contentBg":"var(--lia-bs-white)","backgroundBg":"var(--lia-bs-white)","smSize":"440px","mdSize":"760px","lgSize":"1080px","backdropOpacity":0.3,"contentBoxShadowXs":"var(--lia-bs-box-shadow-sm)","contentBoxShadow":"var(--lia-bs-box-shadow)","headerFontWeight":"700","__typename":"ModalThemeSettings"},"navbar":{"position":"FIXED","background":{"attachment":null,"clip":null,"color":"var(--lia-bs-white)","imageAssetName":"","imageLastModified":"0","origin":null,"position":"CENTER_CENTER","repeat":"NO_REPEAT","size":"COVER","__typename":"BackgroundProps"},"backgroundOpacity":0.8,"paddingTop":"15px","paddingBottom":"15px","borderBottom":"1px solid var(--lia-bs-border-color)","boxShadow":"var(--lia-bs-box-shadow-sm)","brandMarginRight":"30px","brandMarginRightSm":"10px","brandLogoHeight":"30px","linkGap":"10px","linkJustifyContent":"flex-start","linkPaddingY":"5px","linkPaddingX":"10px","linkDropdownPaddingY":"9px","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkColor":"var(--lia-bs-body-color)","linkHoverColor":"var(--lia-bs-primary)","linkFontSize":"var(--lia-bs-font-size-sm)","linkFontStyle":"NORMAL","linkFontWeight":"400","linkTextTransform":"NONE","linkLetterSpacing":"normal","linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkBgColor":"transparent","linkBgHoverColor":"transparent","linkBorder":"none","linkBorderHover":"none","linkBoxShadow":"none","linkBoxShadowHover":"none","linkTextBorderBottom":"none","linkTextBorderBottomHover":"none","dropdownPaddingTop":"10px","dropdownPaddingBottom":"15px","dropdownPaddingX":"10px","dropdownMenuOffset":"2px","dropdownDividerMarginTop":"10px","dropdownDividerMarginBottom":"10px","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","controllerIconColor":"var(--lia-bs-body-color)","controllerIconHoverColor":"var(--lia-bs-body-color)","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","controllerHighlightColor":"hsla(30, 100%, 50%)","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerColor":"var(--lia-nav-controller-icon-color)","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","hamburgerBgColor":"transparent","hamburgerBgHoverColor":"transparent","hamburgerBorder":"none","hamburgerBorderHover":"none","collapseMenuMarginLeft":"20px","collapseMenuDividerBg":"var(--lia-nav-link-color)","collapseMenuDividerOpacity":0.16,"__typename":"NavbarThemeSettings"},"pager":{"textColor":"var(--lia-bs-link-color)","textFontWeight":"var(--lia-font-weight-md)","textFontSize":"var(--lia-bs-font-size-sm)","__typename":"PagerThemeSettings"},"panel":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-bs-border-radius)","borderColor":"var(--lia-bs-border-color)","boxShadow":"none","__typename":"PanelThemeSettings"},"popover":{"arrowHeight":"8px","arrowWidth":"16px","maxWidth":"300px","minWidth":"100px","headerBg":"var(--lia-bs-white)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius)","boxShadow":"0 0.5rem 1rem hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.15)","__typename":"PopoverThemeSettings"},"prism":{"color":"#000000","bgColor":"#f5f2f0","fontFamily":"var(--font-family-monospace)","fontSize":"var(--lia-bs-font-size-base)","fontWeightBold":"var(--lia-bs-font-weight-bold)","fontStyleItalic":"italic","tabSize":2,"highlightColor":"#b3d4fc","commentColor":"#62707e","punctuationColor":"#6f6f6f","namespaceOpacity":"0.7","propColor":"#990055","selectorColor":"#517a00","operatorColor":"#906736","operatorBgColor":"hsla(0, 0%, 100%, 0.5)","keywordColor":"#0076a9","functionColor":"#d3284b","variableColor":"#c14700","__typename":"PrismThemeSettings"},"rte":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":" var(--lia-panel-box-shadow)","customColor1":"#bfedd2","customColor2":"#fbeeb8","customColor3":"#f8cac6","customColor4":"#eccafa","customColor5":"#c2e0f4","customColor6":"#2dc26b","customColor7":"#f1c40f","customColor8":"#e03e2d","customColor9":"#b96ad9","customColor10":"#3598db","customColor11":"#169179","customColor12":"#e67e23","customColor13":"#ba372a","customColor14":"#843fa1","customColor15":"#236fa1","customColor16":"#ecf0f1","customColor17":"#ced4d9","customColor18":"#95a5a6","customColor19":"#7e8c8d","customColor20":"#34495e","customColor21":"#000000","customColor22":"#ffffff","defaultMessageHeaderMarginTop":"40px","defaultMessageHeaderMarginBottom":"20px","defaultMessageItemMarginTop":"0","defaultMessageItemMarginBottom":"30px","diffAddedColor":"hsla(170, 53%, 51%, 0.4)","diffChangedColor":"hsla(43, 97%, 63%, 0.4)","diffNoneColor":"hsla(0, 0%, 80%, 0.4)","diffRemovedColor":"hsla(9, 74%, 47%, 0.4)","specialMessageHeaderMarginTop":"40px","specialMessageHeaderMarginBottom":"20px","specialMessageItemMarginTop":"0","specialMessageItemMarginBottom":"30px","__typename":"RteThemeSettings"},"tags":{"bgColor":"var(--lia-bs-gray-200)","bgHoverColor":"var(--lia-bs-gray-400)","borderRadius":"var(--lia-bs-border-radius-sm)","color":"var(--lia-bs-body-color)","hoverColor":"var(--lia-bs-body-color)","fontWeight":"var(--lia-font-weight-md)","fontSize":"var(--lia-font-size-xxs)","textTransform":"UPPERCASE","letterSpacing":"0.5px","__typename":"TagsThemeSettings"},"toasts":{"borderRadius":"var(--lia-bs-border-radius)","paddingX":"12px","__typename":"ToastsThemeSettings"},"typography":{"fontFamilyBase":"Aeonik","fontStyleBase":"NORMAL","fontWeightBase":"400","fontWeightLight":"300","fontWeightNormal":"400","fontWeightMd":"500","fontWeightBold":"700","letterSpacingSm":"normal","letterSpacingXs":"normal","lineHeightBase":"1.5","fontSizeBase":"18px","fontSizeXxs":"11px","fontSizeXs":"14px","fontSizeSm":"16px","fontSizeLg":"20px","fontSizeXl":"24px","smallFontSize":"14px","customFonts":[{"source":"SERVER","name":"Aeonik","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"},{"style":"ITALIC","weight":"400","__typename":"FontStyleData"},{"style":"NORMAL","weight":"700","__typename":"FontStyleData"},{"style":"ITALIC","weight":"700","__typename":"FontStyleData"}],"assetNames":["Aeonik-normal-400.woff2","Aeonik-italic-400.woff2","Aeonik-normal-700.woff2","Aeonik-italic-700.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Aeonik Pro","styles":[{"style":"NORMAL","weight":"700","__typename":"FontStyleData"},{"style":"NORMAL","weight":"400","__typename":"FontStyleData"}],"assetNames":["AeonikPro-normal-700.woff2","AeonikPro-normal-400.woff2"],"__typename":"CustomFont"}],"__typename":"TypographyThemeSettings"},"unstyledListItem":{"marginBottomSm":"5px","marginBottomMd":"10px","marginBottomLg":"15px","marginBottomXl":"20px","marginBottomXxl":"25px","__typename":"UnstyledListItemThemeSettings"},"yiq":{"light":"#ffffff","dark":"#000000","__typename":"YiqThemeSettings"},"colorLightness":{"primaryDark":0.36,"primaryLight":0.74,"primaryLighter":0.89,"primaryLightest":0.95,"infoDark":0.39,"infoLight":0.72,"infoLighter":0.85,"infoLightest":0.93,"successDark":0.24,"successLight":0.62,"successLighter":0.8,"successLightest":0.91,"warningDark":0.39,"warningLight":0.68,"warningLighter":0.84,"warningLightest":0.93,"dangerDark":0.41,"dangerLight":0.72,"dangerLighter":0.89,"dangerLightest":0.95,"__typename":"ColorLightnessThemeSettings"},"localOverride":false,"__typename":"Theme"},"localOverride":false},"CachedAsset:text:en_US-components/common/EmailVerification-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/common/EmailVerification-1738256407000","value":{"email.verification.title":"Email Verification Required","email.verification.message.update.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. To change your email, visit My Settings.","email.verification.message.resend.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. Resend email."},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-1738256407000","value":{"title":"Loading..."},"localOverride":false},"CachedAsset:quilt:campingworld.prod:pages/forums/ForumMessagePage:board:TravelTrailerforum-board-1739912389551":{"__typename":"CachedAsset","id":"quilt:campingworld.prod:pages/forums/ForumMessagePage:board:TravelTrailerforum-board-1739912389551","value":{"id":"ForumMessagePage","container":{"id":"Common","headerProps":{"backgroundImageProps":null,"backgroundColor":null,"addComponents":null,"removeComponents":["community.widget.bannerWidget"],"componentOrder":null,"__typename":"QuiltContainerSectionProps"},"headerComponentProps":{"community.widget.breadcrumbWidget":{"disableLastCrumbForDesktop":false}},"footerProps":null,"footerComponentProps":null,"items":[{"id":"message-list","layout":"MAIN_SIDE","bgColor":null,"showTitle":null,"showDescription":null,"textPosition":null,"textColor":null,"sectionEditLevel":null,"bgImage":null,"disableSpacing":null,"edgeToEdgeDisplay":null,"fullHeight":null,"showBorder":null,"__typename":"MainSideQuiltSection","columnMap":{"main":[{"id":"messages.widget.topicWithThreadedReplyListWidget","className":"lia-topic-with-replies","props":{"editLevel":"CONFIGURE"},"__typename":"QuiltComponent"}],"side":[{"id":"nodes.widget.nodeActionButtonWidget","className":null,"props":{"buttonAlignment":"right","instanceId":null,"buttonStyle":"md","actionButtonTitle":"Start a New Discussion","lazyLoad":false,"buttonWidth":"full_width"},"__typename":"QuiltComponent"},{"id":"nodes.widget.nodeInformationWidget","className":null,"props":{"instanceId":null,"useWidgetTitle":true,"viewVariant":{"type":"card","props":{"useNodePostCount":true,"useNodeFollowersCount":false,"useNodeDescription":true,"useNodeTopicsCount":false,"useNodeAction":true,"useNodeMembersCount":false,"useNodeMembershipType":false,"useNodeTitle":false,"useNodeMembersCountText":false,"useNodeMembership":false,"useNodeCreationDate":false,"textAlignment":"center","useWidgetTitle":true,"useNodeOwners":false,"useNodeAvatar":false,"useNodeLatestActivityTime":true,"descriptionClampLines":2,"useClickableCard":false}},"alignment":"center","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"messages.widget.relatedContentWidget","className":null,"props":{"hideIfEmpty":true,"enablePagination":false,"useTitle":true,"listVariant":{"type":"unstyled","props":{"listItemSpacing":"xxl"}},"pageSize":5,"style":"compact","pagerVariant":{"type":"none"},"viewVariant":{"type":"inline","props":{"useRepliesCount":false,"useMedia":false,"useAuthorRank":false,"useNode":false,"boardIconSize":"24","useAuthorLoginLink":true,"useNodeLink":true,"usePreviewMedia":true,"timeStampType":"postTime","useTextBody":true,"useSolvedBadge":false,"subjectAs":"h6","renderPostTimeBeforeAuthor":true,"useAvatar":true,"useVideoPreview":false,"portraitClampBodyLines":3,"useCompactSpacing":true,"useTimeToRead":false,"useSpoilerFreeBody":true,"useKudosCount":false,"useViewCount":false,"useBody":false,"useTags":false,"clampSubjectLines":1,"useBoardIcon":false,"useMessageTimeLink":true,"useAuthorLogin":true}},"lazyLoad":false,"panelType":"standard"},"__typename":"QuiltComponent"}],"__typename":"MainSideSectionColumns"}}],"__typename":"QuiltContainer"},"__typename":"Quilt","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-pages/forums/ForumMessagePage-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-pages/forums/ForumMessagePage-1738256407000","value":{"title":"{contextMessageSubject} | {communityTitle}","errorMissing":"This message cannot be found","name":"Forum Message Page","section.message-list.title":"Forum Discussion","archivedMessageTitle":"This Content Has Been Archived"},"localOverride":false},"CachedAsset:quiltWrapper:campingworld.prod:Common:1739278961221":{"__typename":"CachedAsset","id":"quiltWrapper:campingworld.prod:Common:1739278961221","value":{"id":"Common","header":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"transparent","items":[{"id":"community.widget.navbarWidget","props":{"showUserName":true,"showRegisterLink":true,"useIconLanguagePicker":true,"useLabelLanguagePicker":true,"links":{"sideLinks":[{"children":[],"linkType":"EXTERNAL","id":"migrated-link-7","url":"https://www.goodsam.com","target":"BLANK"},{"children":[],"linkType":"EXTERNAL","id":"migrated-link-8","url":"https://myaccount.goodsam.com/myrewards","target":"BLANK"}],"mainLinks":[{"children":[],"linkType":"INTERNAL","id":"migrated-link-0","params":{"categoryId":"RVTalk"},"routeName":"CategoryPage"},{"children":[],"linkType":"INTERNAL","id":"migrated-link-1","params":{"categoryId":"TRAVELCENTER"},"routeName":"CategoryPage"},{"children":[{"linkType":"INTERNAL","id":"Common-announcements_blog-link","params":{"boardId":"Announcements_Blog","categoryId":"top"},"routeName":"BlogBoardPage"},{"linkType":"INTERNAL","id":"Common-get-support-ask-questions-link","params":{"boardId":"GetSupportAskQuestions","categoryId":"top"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"Common-community-feedback-link","params":{"boardId":"CommunityFeedback","categoryId":"top"},"routeName":"ForumBoardPage"}],"linkType":"INTERNAL","id":"migrated-link-3","params":{"boardId":"Announcements_Blog","categoryId":"top"},"routeName":"BlogBoardPage"},{"children":[],"linkType":"INTERNAL","id":"Common-admin-mods-private-link","params":{"categoryId":"AdminModsPrivate"},"routeName":"CategoryPage"}]},"className":"QuiltComponent_lia-component-edit-mode__0nCcm","style":{"boxShadow":"var(--lia-bs-box-shadow-sm)","linkFontWeight":"400","controllerHighlightColor":"var(--lia-bs-body-color)","dropdownDividerMarginBottom":"10px","hamburgerBorderHover":"none","linkFontSize":"16px","linkBoxShadowHover":"none","backgroundOpacity":0.8,"controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerBgColor":"transparent","linkTextBorderBottom":"none","hamburgerColor":"var(--lia-nav-controller-icon-color)","brandLogoHeight":"30px","linkLetterSpacing":"normal","linkBgHoverColor":"transparent","collapseMenuDividerOpacity":0.16,"paddingBottom":"15px","dropdownPaddingBottom":"15px","dropdownMenuOffset":"2px","hamburgerBgHoverColor":"transparent","borderBottom":"1px solid var(--lia-bs-border-color)","hamburgerBorder":"none","dropdownPaddingX":"10px","brandMarginRightSm":"10px","linkBoxShadow":"none","linkJustifyContent":"flex-start","linkColor":"notFound","collapseMenuDividerBg":"var(--lia-nav-link-color)","dropdownPaddingTop":"10px","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerTextColor":"var(--lia-nav-controller-icon-color)","background":{"imageAssetName":"","color":"var(--lia-bs-white)","size":"COVER","repeat":"NO_REPEAT","position":"CENTER_CENTER","imageLastModified":""},"linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkHoverColor":"notFound","position":"FIXED","linkBorder":"none","linkTextBorderBottomHover":"2px solid var(--lia-bs-primary)","brandMarginRight":"30px","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","linkBorderHover":"none","collapseMenuMarginLeft":"20px","linkFontStyle":"NORMAL","linkPaddingX":"10px","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","paddingTop":"15px","linkPaddingY":"5px","linkTextTransform":"NONE","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkBgColor":"transparent","linkDropdownPaddingY":"9px","controllerIconColor":"var(--lia-bs-body-color)","dropdownDividerMarginTop":"10px","linkGap":"10px","controllerIconHoverColor":"var(--lia-bs-body-color)"},"showSearchIcon":true,"languagePickerStyle":"iconAndLabel"},"__typename":"QuiltComponent"},{"id":"community.widget.breadcrumbWidget","props":{"backgroundColor":"transparent","linkHighlightColor":"var(--lia-bs-gray-600)","visualEffects":{"showBottomBorder":true},"linkTextColor":"var(--lia-bs-black)"},"__typename":"QuiltComponent"},{"id":"community.widget.bannerWidget","props":null,"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"footer":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"transparent","items":[{"id":"custom.widget.CustomFooter","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"community.widget.footerWidget","props":null,"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"__typename":"QuiltWrapper","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/ActionFeedback-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/common/ActionFeedback-1738256407000","value":{"joinedGroupHub.title":"Welcome","joinedGroupHub.message":"You are now a member of this group and are subscribed to updates.","groupHubInviteNotFound.title":"Invitation Not Found","groupHubInviteNotFound.message":"Sorry, we could not find your invitation to the group. The owner may have canceled the invite.","groupHubNotFound.title":"Group Not Found","groupHubNotFound.message":"The grouphub you tried to join does not exist. It may have been deleted.","existingGroupHubMember.title":"Already Joined","existingGroupHubMember.message":"You are already a member of this group.","accountLocked.title":"Account Locked","accountLocked.message":"Your account has been locked due to multiple failed attempts. Try again in {lockoutTime} minutes.","editedGroupHub.title":"Changes Saved","editedGroupHub.message":"Your group has been updated.","leftGroupHub.title":"Goodbye","leftGroupHub.message":"You are no longer a member of this group and will not receive future updates.","deletedGroupHub.title":"Deleted","deletedGroupHub.message":"The group has been deleted.","groupHubCreated.title":"Group Created","groupHubCreated.message":"{groupHubName} is ready to use","accountClosed.title":"Account Closed","accountClosed.message":"The account has been closed and you will now be redirected to the homepage","resetTokenExpired.title":"Reset Password Link has Expired","resetTokenExpired.message":"Try resetting your password again","invalidUrl.title":"Invalid URL","invalidUrl.message":"The URL you're using is not recognized. Verify your URL and try again.","accountClosedForUser.title":"Account Closed","accountClosedForUser.message":"{userName}'s account is closed","inviteTokenInvalid.title":"Invitation Invalid","inviteTokenInvalid.message":"Your invitation to the community has been canceled or expired.","inviteTokenError.title":"Invitation Verification Failed","inviteTokenError.message":"The url you are utilizing is not recognized. Verify your URL and try again","pageNotFound.title":"Access Denied","pageNotFound.message":"You do not have access to this area of the community or it doesn't exist","eventAttending.title":"Responded as Attending","eventAttending.message":"You'll be notified when there's new activity and reminded as the event approaches","eventInterested.title":"Responded as Interested","eventInterested.message":"You'll be notified when there's new activity and reminded as the event approaches","eventNotFound.title":"Event Not Found","eventNotFound.message":"The event you tried to respond to does not exist.","redirectToRelatedPage.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.message":"The content you are trying to access is archived","redirectToRelatedPage.message":"The content you are trying to access is archived","relatedUrl.archivalLink.flyoutMessage":"The content you are trying to access is archived View Archived Content"},"localOverride":false},"CachedAsset:component:custom.widget.CustomFooter-en-1739279048072":{"__typename":"CachedAsset","id":"component:custom.widget.CustomFooter-en-1739279048072","value":{"component":{"id":"custom.widget.CustomFooter","template":{"id":"CustomFooter","markupLanguage":"HANDLEBARS","style":"$bootstrap-padding: 15px;\n$goodsam-gray: #474442;\n$goodsam-gray-200: #eaecef;\n$goodsam-gray-400: #c7c7c7;\n$goodsam-gray-700: #666;\n$goodsam-gray-footer: #dfdfdf;\n\n$theme-type-size-xsmall: 12px;\n$theme-type-size-small: 14px;\n$theme-type-size-base: 16px;\n$theme-type-size-large: 18px;\n$theme-type-size-xlarge: 20px;\n\n$font-weight-content: 100;\n\n$theme-space-xsmall: 5px;\n$theme-space-small: 10px;\n$theme-space-base: 20px;\n$theme-space-large: 40px;\n$theme-space-xlarge: 60px;\n.footer-wrapper {\n background: $goodsam-gray;\n\n a {\n color: $goodsam-gray-footer;\n font-weight: $font-weight-content;\n\n &:focus,\n &:hover {\n color: $goodsam-gray-footer;\n }\n }\n}\n.sr-only {\n position: absolute;\n width: 1px;\n height: 1px;\n margin: -1px;\n padding: 0;\n overflow: hidden;\n clip: rect(0, 0, 0, 0);\n border: 0;\n}\n.footer {\n line-height: $theme-type-size-xlarge;\n /* margin-left: auto;\n\tmargin-right: auto;\n\tpadding-left: $bootstrap-padding;\n\tpadding-right: $bootstrap-padding; */\n}\n\n.container {\n margin-left: auto;\n margin-right: auto;\n max-width: 1170px;\n padding-left: $bootstrap-padding;\n padding-right: $bootstrap-padding;\n}\n\n.row {\n /* HOTFIX - PSDS-32115 - Remove negative margins to fix mobile display */\n\n &::after {\n clear: both;\n }\n\n &::after,\n &::before {\n content: ' ';\n display: table;\n }\n}\n\n.col {\n float: left;\n min-height: 1px;\n padding-left: $bootstrap-padding;\n padding-right: $bootstrap-padding;\n position: relative;\n}\n\n.col-xs-10,\n.col-sm-10 {\n width: 83.33333333%;\n}\n\n.col-xs-12,\n.col-sm-4,\n.col-sm-12,\n.col-md-2,\n.col-md-8,\n.col-md-10,\n.col-md-12,\n.col-lg-2,\n.col-lg-8,\n.col-lg-12 {\n width: 100%;\n}\n\n@media screen and (min-width: 767px) {\n .col-md-2 {\n width: 16.66666667%;\n }\n\n .col-md-8 {\n width: 66.66666667%;\n }\n\n .col-md-10 {\n width: 83.33333333%;\n }\n\n .col-md-12 {\n width: 100%;\n }\n}\n\n@media screen and (min-width: 992px) {\n .col-lg-2 {\n width: 16.66666667%;\n }\n\n .col-lg-4 {\n /* faking it; should be 33.33333333% */\n width: 25%;\n }\n\n .col-lg-8 {\n /* faking it; should be 66.66666667% */\n width: 75%;\n }\n\n .col-lg-10 {\n width: 83.33333333%;\n }\n\n .col-lg-12 {\n width: 100%;\n }\n}\n\n.pull-left {\n float: left;\n width: 100%;\n\n @media screen and (min-width: 767px) {\n float: none;\n width: auto;\n }\n\n @media screen and (min-width: 992px) {\n float: left;\n }\n}\n\n.pad-bottom-20 {\n padding-bottom: $theme-space-base;\n}\n\n.pad-top-20 {\n padding-top: $theme-space-base;\n}\n\n.pad-top-30 {\n padding-top: calc($bootstrap-padding * 2);\n}\n\n.pad-top-40 {\n @media screen and (min-width: 992px) {\n padding-top: $theme-space-large;\n }\n}\n\n.margin-left-20 {\n @media screen and (min-width: 992px) {\n margin-left: $theme-space-base;\n }\n}\n\n.margin-top-20 {\n @media screen and (min-width: 992px) {\n margin-top: $theme-space-base;\n }\n}\n\n.text-center {\n text-align: center;\n}\n\n.text-right {\n text-align: right;\n}\n\n.text-smaller,\n.text-small {\n font-size: $theme-type-size-xsmall;\n}\n\n.text-large {\n font-size: $theme-type-size-xlarge;\n}\n\n.footer-contact {\n p {\n display: flex;\n flex-direction: row;\n justify-content: center;\n align-items: center;\n\n @media screen and (min-width: 992px) {\n display: block;\n }\n\n .text-small {\n @media screen and (max-width: 991px) {\n font-size: $theme-type-size-base;\n }\n }\n }\n\n .icon-gs-app {\n margin-right: $theme-space-base;\n max-width: 38px;\n padding-right: 2px;\n padding-top: 2px;\n\n @media screen and (min-width: 992px) {\n margin-left: 140px;\n margin-right: 0;\n }\n }\n\n .gsi-icon-phone {\n margin-bottom: -2px;\n margin-right: $theme-space-small;\n max-height: 20px;\n width: 20px;\n\n @media screen and (min-width: 992px) {\n margin-right: 0;\n }\n }\n}\n\n.footer-link {\n a,\n button {\n color: $goodsam-gray-footer;\n padding: 0 12px 0 $theme-space-small;\n }\n\n li:last-child a {\n padding-right: 0;\n }\n}\n\n.footer-top-links {\n padding-left: 0;\n list-style: none;\n display: flex;\n flex-direction: row;\n justify-content: center;\n align-items: center;\n flex-wrap: wrap;\n margin-bottom: $theme-space-small;\n font-size: 16px;\n\n @media screen and (max-width: 480px) {\n flex-direction: column;\n }\n\n @media screen and (min-width: 992px) {\n display: block;\n }\n\n li {\n margin-bottom: $theme-space-base;\n padding: 0 $theme-space-base;\n\n @media screen and (min-width: 992px) {\n padding: 0;\n }\n }\n}\n\n.footer-top {\n border-bottom: 2px solid $goodsam-gray-400;\n display: block;\n margin: auto;\n padding-top: $theme-space-small;\n text-align: center;\n\n @media screen and (min-width: 992px) {\n text-align: left;\n }\n\n .footer-logo {\n max-height: 60px;\n max-width: 140px;\n padding: $theme-space-small;\n padding-left: 0;\n padding-top: 0;\n }\n\n .footer-list {\n display: flex;\n justify-content: center;\n align-items: center;\n list-style: none;\n margin-bottom: 0;\n\n @media screen and (min-width: 992px) {\n display: block;\n float: right;\n }\n\n li {\n display: inline-block;\n padding: $theme-space-small $theme-space-xsmall;\n\n @media screen and (min-width: 992px) {\n border-right: 1px solid $goodsam-gray-700;\n float: left;\n padding: 0;\n\n &:last-child {\n border-right: 0;\n }\n }\n\n a,\n button {\n font-size: $theme-type-size-xsmall;\n text-transform: uppercase;\n\n @media screen and (max-width: 768px) {\n display: block;\n padding: $theme-space-small;\n }\n\n @media screen and (min-width: 992px) {\n font-size: $theme-type-size-small;\n }\n }\n\n .dropup {\n background-clip: padding-box;\n border: none;\n font-size: $theme-type-size-small;\n list-style: none;\n padding-left: 5px;\n position: relative;\n\n @media screen and (min-width: 992px) {\n float: left;\n }\n\n &:hover {\n .dropdown-menu {\n display: block;\n }\n }\n }\n\n .footer-dropup-toggle {\n background: none;\n border: 0;\n padding: 0;\n\n .fa-angle-up {\n /* @include li-icon ($fa-var-angle-up, $pseudo: before, $size: $theme-type-size-base, $color: $goodsam-gray-footer);\n padding-left: $theme-space-xsmall;\n padding-right: $theme-space-xsmall; */\n }\n }\n\n .dropdown-menu {\n background-color: #fff;\n border-radius: 4px;\n bottom: 100%;\n margin: 2px 0 0;\n min-width: 160px;\n padding: $theme-space-xsmall 0;\n position: absolute;\n right: 0;\n\n li {\n border-right: 0;\n float: none;\n text-align: left;\n\n @media screen and (max-width: 768px) {\n display: block;\n }\n\n a {\n color: $goodsam-gray;\n display: block;\n text-transform: none;\n\n &:hover {\n outline: 5px auto -webkit-focus-ring-color;\n outline-offset: -2px;\n }\n }\n }\n }\n }\n }\n}\n\n.footer-terms {\n display: flex;\n flex-direction: column;\n justify-content: center;\n align-items: center;\n padding: $theme-space-small 0;\n\n @media screen and (min-width: 992px) {\n display: block;\n padding: 0;\n }\n\n > .row {\n padding-bottom: $theme-space-small;\n\n @media screen and (min-width: 992px) {\n padding-bottom: $theme-space-base;\n }\n\n &.footer-terms-order-1 {\n order: 1;\n }\n\n &.footer-terms-order-2 {\n order: 2;\n }\n }\n}\n\n.footer-bottom {\n @media screen and (min-width: 992px) {\n padding-top: $theme-space-small;\n }\n\n .footer-bottom-list-center {\n display: flex;\n flex-direction: row;\n justify-content: center;\n align-items: center;\n flex-wrap: wrap;\n float: none;\n margin: 0 auto;\n\n @media screen and (min-width: 992px) {\n display: block;\n }\n\n li {\n display: inline;\n padding: 0 $theme-space-base;\n\n @media screen and (min-width: 992px) {\n border-right: 1px solid $goodsam-gray-700;\n padding: 0;\n\n &:first-child a {\n padding-left: 0;\n }\n\n &:last-child {\n border-right: 0;\n\n a {\n padding-right: 0;\n }\n }\n }\n\n a {\n display: inline-block;\n font-size: $theme-type-size-small;\n padding: $theme-space-small;\n\n @media screen and (min-width: 992px) {\n display: inline;\n font-size: $theme-type-size-xsmall;\n padding: 0 12px 0 $theme-space-small;\n }\n }\n }\n }\n}\n\n.copyright {\n color: $goodsam-gray-footer;\n font-size: $theme-type-size-base;\n margin-bottom: 0;\n\n @media screen and (min-width: 992px) {\n margin-bottom: $theme-space-small;\n }\n}\n\n#gsFooterSocial,\n.gsFooterSocial {\n background: $goodsam-gray-200;\n padding: 0 calc($theme-space-small + $theme-space-xsmall);\n .footerSocialItems,\n #footerSocialItems {\n text-align: center;\n\n @media screen and (min-width: 767px) {\n text-align: left;\n }\n }\n\n .footerSocialItems ul,\n #footerSocialItems ul {\n list-style-type: none;\n margin: auto;\n padding-left: 0;\n\n li {\n display: inline;\n margin: 0 $theme-space-small;\n }\n }\n}\n","texts":{"custom.footer.col01.text.01":"Home","custom.footer.col01.url.01":"https://www.goodsam.com/","custom.footer.col01.text.02":"About Us","custom.footer.col01.url.02":"https://www.goodsam.com/about/","custom.footer.col01.text.03":"Contact Us","custom.footer.col01.url.03":"https://www.goodsam.com/contact","custom.footer.col01.text.04":"FAQ","custom.footer.col01.url.04":"https://www.goodsam.com/faq/","custom.footer.col01.text.05":"Site Map","custom.footer.col01.url.05":"https://www.goodsam.com/site-map.aspx","custom.footer.col02.text.01":"Code of Conduct","custom.footer.col02.url.01":"https://www.goodsam.com/code-of-conduct.aspx","custom.footer.col02.text.02":"Affiliate Program","custom.footer.col02.url.02":"https://www.goodsam.com/affiliate/","custom.footer.col02.text.03":"Become a Good Sam Campground","custom.footer.col02.url.03":"https://www.goodsamnetwork.com/","custom.footer.col02.text.04":"Good Sam Rewards Visa","custom.footer.col02.url.04":"https://www.goodsam.com/creditcard/","custom.footer.col02.text.05":"About Marcus Lemonis","custom.footer.col02.url.05":"https://www.goodsam.com/about-marcus-lemonis/","custom.footer.col03.text.01":"RV Sales","custom.footer.col03.url.01":"https://rv.campingworld.com/","custom.footer.col03.text.02":"RV Gear","custom.footer.col03.url.02":"https://www.campingworld.com/shop/","custom.footer.col03.text.03":"RV Maintenance & Repair","custom.footer.col03.url.03":"https://rv.campingworld.com/service/","custom.footer.col03.text.04":"Good Sam Membership & Services","custom.footer.col03.url.04":"https://www.goodsam.com/","custom.footer.col03.text.05":"Campground Solutions","custom.footer.col03.url.05":"https://campgroundsolutions.goodsam.com/","custom.footer.col04.text.01":"Helpful Articles and Tips","custom.footer.col04.url.01":"https://www.goodsam.com/article","custom.footer.col05.text.01":"Good Sam Apps","custom.footer.col05.url.01":"https://www.goodsam.com/rv-camping-apps/","custom.footer.col05.text.02":"Take Good Sam apps on your next RV Trip!","custom.footer.col05.url.02":"https://www.goodsam.com/rv-camping-apps/","custom.footer.col06.text.01":"Customer Service Phone Number:","custom.footer.col06.phone.number":"866-205-7451","custom.footer.col06.text.02":"Club contact number 866-205-7451","custom.footer.col06.url.02":"tel:866-205-7451","custom.footer.row01.logo.text":"Good Sam Home","custom.footer.row01.text.01":"Blog","custom.footer.row01.url.01":"http://blog.goodsam.com/","custom.footer.row01.text.02":"Careers","custom.footer.row01.url.02":"https://www.campingworldcareers.com/","custom.footer.row01.text.03":"Contact Us","custom.footer.row01.text.toggle":"Click to expand","custom.footer.row01.text.04":"Good Sam","custom.footer.row01.url.04":"https://www.goodsam.com/contact/","custom.footer.row01.text.05":"Camping World","custom.footer.row01.url.05":"https://www.campingworld.com/contact/","custom.footer.row01.text.06":"RV Sales","custom.footer.row01.url.06":"https://rv.campingworld.com/contact","custom.footer.row02.text.01":"Privacy Policy","custom.footer.row02.url.01":"https://www.goodsam.com/privacy-policy.aspx","custom.footer.row02.text.02":"California Privacy Rights","custom.footer.row02.url.02":"https://www.goodsam.com/privacy-policy.aspx#calinevada","custom.footer.row02.text.03":"Investor Relations","custom.footer.row02.url.03":"http://investor.campingworld.com","custom.footer.row02.text.04":"Terms of Use","custom.footer.row02.url.04":"https://www.goodsam.com/terms.aspx","custom.footer.row02.text.05":"Accessibility Commitment","custom.footer.row02.url.05":"https://www.goodsam.com/accessibility-commitment.aspx","custom.footer.row02.text.06":"Team Member Assistance","custom.footer.row02.url.06":"https://www.goodsam.com/helping-hand","custom.footer.social.facebook.text":"Facebook","custom.footer.social.facebook.url":"https://www.facebook.com/GoodSam","custom.footer.social.twitter.text":"Twitter","custom.footer.social.twitter.url":"https://twitter.com/GoodSam","custom.footer.social.youtube.text":"YouTube","custom.footer.social.youtube.url":"https://www.youtube.com/user/goodsamrvers","custom.footer.social.instagram.text":"Instagram","custom.footer.social.instagram.url":"https://www.instagram.com/goodsam/?hl=en","custom.footer.social.pinterest.text":"Pinterest","custom.footer.social.pinterest.url":"https://www.pinterest.com/goodsam/","custom-community-footer-copyright.text":"© {0} Good Sam Enterprises, LLC. All rights reserved."},"defaults":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.CustomFooter","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":{"css":".custom_widget_CustomFooter_footer-wrapper_hp49n_21 {\n background: #474442;\n\n a {\n color: #dfdfdf;\n font-weight: 100;\n\n &:focus,\n &:hover {\n color: #dfdfdf;\n }\n }\n}\n.custom_widget_CustomFooter_sr-only_hp49n_34 {\n position: absolute;\n width: 0.0625rem;\n height: 0.0625rem;\n margin: -0.0625rem;\n padding: 0;\n overflow: hidden;\n clip: rect(0, 0, 0, 0);\n border: 0;\n}\n.custom_widget_CustomFooter_footer_hp49n_21 {\n line-height: 1.25rem;\n /* margin-left: auto;\n\tmargin-right: auto;\n\tpadding-left: $bootstrap-padding;\n\tpadding-right: $bootstrap-padding; */\n}\n.custom_widget_CustomFooter_container_hp49n_52 {\n margin-left: auto;\n margin-right: auto;\n max-width: 73.125rem;\n padding-left: 0.9375rem;\n padding-right: 0.9375rem;\n}\n.custom_widget_CustomFooter_row_hp49n_60 {\n /* HOTFIX - PSDS-32115 - Remove negative margins to fix mobile display */\n\n &::after {\n clear: both;\n }\n\n &::after,\n &::before {\n content: ' ';\n display: table;\n }\n}\n.custom_widget_CustomFooter_col_hp49n_74 {\n float: left;\n min-height: 0.0625rem;\n padding-left: 0.9375rem;\n padding-right: 0.9375rem;\n position: relative;\n}\n.custom_widget_CustomFooter_col-xs-10_hp49n_82,\n.custom_widget_CustomFooter_col-sm-10_hp49n_83 {\n width: 83.33333333%;\n}\n.custom_widget_CustomFooter_col-xs-12_hp49n_87,\n.custom_widget_CustomFooter_col-sm-4_hp49n_88,\n.custom_widget_CustomFooter_col-sm-12_hp49n_89,\n.custom_widget_CustomFooter_col-md-2_hp49n_90,\n.custom_widget_CustomFooter_col-md-8_hp49n_91,\n.custom_widget_CustomFooter_col-md-10_hp49n_92,\n.custom_widget_CustomFooter_col-md-12_hp49n_93,\n.custom_widget_CustomFooter_col-lg-2_hp49n_94,\n.custom_widget_CustomFooter_col-lg-8_hp49n_95,\n.custom_widget_CustomFooter_col-lg-12_hp49n_96 {\n width: 100%;\n}\n@media screen and (min-width: 767px) {\n .custom_widget_CustomFooter_col-md-2_hp49n_90 {\n width: 16.66666667%;\n }\n\n .custom_widget_CustomFooter_col-md-8_hp49n_91 {\n width: 66.66666667%;\n }\n\n .custom_widget_CustomFooter_col-md-10_hp49n_92 {\n width: 83.33333333%;\n }\n\n .custom_widget_CustomFooter_col-md-12_hp49n_93 {\n width: 100%;\n }\n}\n@media screen and (min-width: 992px) {\n .custom_widget_CustomFooter_col-lg-2_hp49n_94 {\n width: 16.66666667%;\n }\n\n .custom_widget_CustomFooter_col-lg-4_hp49n_123 {\n /* faking it; should be 33.33333333% */\n width: 25%;\n }\n\n .custom_widget_CustomFooter_col-lg-8_hp49n_95 {\n /* faking it; should be 66.66666667% */\n width: 75%;\n }\n\n .custom_widget_CustomFooter_col-lg-10_hp49n_133 {\n width: 83.33333333%;\n }\n\n .custom_widget_CustomFooter_col-lg-12_hp49n_96 {\n width: 100%;\n }\n}\n.custom_widget_CustomFooter_pull-left_hp49n_142 {\n float: left;\n width: 100%;\n\n @media screen and (min-width: 767px) {\n float: none;\n width: auto;\n }\n\n @media screen and (min-width: 992px) {\n float: left;\n }\n}\n.custom_widget_CustomFooter_pad-bottom-20_hp49n_156 {\n padding-bottom: 1.25rem;\n}\n.custom_widget_CustomFooter_pad-top-20_hp49n_160 {\n padding-top: 1.25rem;\n}\n.custom_widget_CustomFooter_pad-top-30_hp49n_164 {\n padding-top: calc(0.9375rem * 2);\n}\n.custom_widget_CustomFooter_pad-top-40_hp49n_168 {\n @media screen and (min-width: 992px) {\n padding-top: 2.5rem;\n }\n}\n.custom_widget_CustomFooter_margin-left-20_hp49n_174 {\n @media screen and (min-width: 992px) {\n margin-left: 1.25rem;\n }\n}\n.custom_widget_CustomFooter_margin-top-20_hp49n_180 {\n @media screen and (min-width: 992px) {\n margin-top: 1.25rem;\n }\n}\n.custom_widget_CustomFooter_text-center_hp49n_186 {\n text-align: center;\n}\n.custom_widget_CustomFooter_text-right_hp49n_190 {\n text-align: right;\n}\n.custom_widget_CustomFooter_text-smaller_hp49n_194,\n.custom_widget_CustomFooter_text-small_hp49n_194 {\n font-size: 0.75rem;\n}\n.custom_widget_CustomFooter_text-large_hp49n_199 {\n font-size: 1.25rem;\n}\n.custom_widget_CustomFooter_footer-contact_hp49n_203 {\n p {\n display: flex;\n flex-direction: row;\n justify-content: center;\n align-items: center;\n\n @media screen and (min-width: 992px) {\n display: block;\n }\n\n .custom_widget_CustomFooter_text-small_hp49n_194 {\n @media screen and (max-width: 991px) {\n font-size: 1rem;\n }\n }\n }\n\n .custom_widget_CustomFooter_icon-gs-app_hp49n_221 {\n margin-right: 1.25rem;\n max-width: 2.375rem;\n padding-right: 0.125rem;\n padding-top: 0.125rem;\n\n @media screen and (min-width: 992px) {\n margin-left: 8.75rem;\n margin-right: 0;\n }\n }\n\n .custom_widget_CustomFooter_gsi-icon-phone_hp49n_233 {\n margin-bottom: -0.125rem;\n margin-right: 0.625rem;\n max-height: 1.25rem;\n width: 1.25rem;\n\n @media screen and (min-width: 992px) {\n margin-right: 0;\n }\n }\n}\n.custom_widget_CustomFooter_footer-link_hp49n_245 {\n a,\n button {\n color: #dfdfdf;\n padding: 0 0.75rem 0 0.625rem;\n }\n\n li:last-child a {\n padding-right: 0;\n }\n}\n.custom_widget_CustomFooter_footer-top-links_hp49n_257 {\n padding-left: 0;\n list-style: none;\n display: flex;\n flex-direction: row;\n justify-content: center;\n align-items: center;\n flex-wrap: wrap;\n margin-bottom: 0.625rem;\n font-size: 1rem;\n\n @media screen and (max-width: 480px) {\n flex-direction: column;\n }\n\n @media screen and (min-width: 992px) {\n display: block;\n }\n\n li {\n margin-bottom: 1.25rem;\n padding: 0 1.25rem;\n\n @media screen and (min-width: 992px) {\n padding: 0;\n }\n }\n}\n.custom_widget_CustomFooter_footer-top_hp49n_257 {\n border-bottom: 2px solid #c7c7c7;\n display: block;\n margin: auto;\n padding-top: 0.625rem;\n text-align: center;\n\n @media screen and (min-width: 992px) {\n text-align: left;\n }\n\n .custom_widget_CustomFooter_footer-logo_hp49n_297 {\n max-height: 3.75rem;\n max-width: 8.75rem;\n padding: 0.625rem;\n padding-left: 0;\n padding-top: 0;\n }\n\n .custom_widget_CustomFooter_footer-list_hp49n_305 {\n display: flex;\n justify-content: center;\n align-items: center;\n list-style: none;\n margin-bottom: 0;\n\n @media screen and (min-width: 992px) {\n display: block;\n float: right;\n }\n\n li {\n display: inline-block;\n padding: 0.625rem 0.3125rem;\n\n @media screen and (min-width: 992px) {\n border-right: 1px solid #666;\n float: left;\n padding: 0;\n\n &:last-child {\n border-right: 0;\n }\n }\n\n a,\n button {\n font-size: 0.75rem;\n text-transform: uppercase;\n\n @media screen and (max-width: 768px) {\n display: block;\n padding: 0.625rem;\n }\n\n @media screen and (min-width: 992px) {\n font-size: 0.875rem;\n }\n }\n\n .custom_widget_CustomFooter_dropup_hp49n_346 {\n background-clip: padding-box;\n border: none;\n font-size: 0.875rem;\n list-style: none;\n padding-left: 0.3125rem;\n position: relative;\n\n @media screen and (min-width: 992px) {\n float: left;\n }\n\n &:hover {\n .custom_widget_CustomFooter_dropdown-menu_hp49n_359 {\n display: block;\n }\n }\n }\n\n .custom_widget_CustomFooter_footer-dropup-toggle_hp49n_365 {\n background: none;\n border: 0;\n padding: 0;\n\n .custom_widget_CustomFooter_fa-angle-up_hp49n_370 {\n /* @include li-icon ($fa-var-angle-up, $pseudo: before, $size: $theme-type-size-base, $color: $goodsam-gray-footer);\n padding-left: $theme-space-xsmall;\n padding-right: $theme-space-xsmall; */\n }\n }\n\n .custom_widget_CustomFooter_dropdown-menu_hp49n_359 {\n background-color: #fff;\n border-radius: 0.25rem;\n bottom: 100%;\n margin: 0.125rem 0 0;\n min-width: 10rem;\n padding: 0.3125rem 0;\n position: absolute;\n right: 0;\n\n li {\n border-right: 0;\n float: none;\n text-align: left;\n\n @media screen and (max-width: 768px) {\n display: block;\n }\n\n a {\n color: #474442;\n display: block;\n text-transform: none;\n\n &:hover {\n outline: 5px auto -webkit-focus-ring-color;\n outline-offset: -2px;\n }\n }\n }\n }\n }\n }\n}\n.custom_widget_CustomFooter_footer-terms_hp49n_412 {\n display: flex;\n flex-direction: column;\n justify-content: center;\n align-items: center;\n padding: 0.625rem 0;\n\n @media screen and (min-width: 992px) {\n display: block;\n padding: 0;\n }\n\n > .custom_widget_CustomFooter_row_hp49n_60 {\n padding-bottom: 0.625rem;\n\n @media screen and (min-width: 992px) {\n padding-bottom: 1.25rem;\n }\n\n &.custom_widget_CustomFooter_footer-terms-order-1_hp49n_431 {\n order: 1;\n }\n\n &.custom_widget_CustomFooter_footer-terms-order-2_hp49n_435 {\n order: 2;\n }\n }\n}\n.custom_widget_CustomFooter_footer-bottom_hp49n_441 {\n @media screen and (min-width: 992px) {\n padding-top: 0.625rem;\n }\n\n .custom_widget_CustomFooter_footer-bottom-list-center_hp49n_446 {\n display: flex;\n flex-direction: row;\n justify-content: center;\n align-items: center;\n flex-wrap: wrap;\n float: none;\n margin: 0 auto;\n\n @media screen and (min-width: 992px) {\n display: block;\n }\n\n li {\n display: inline;\n padding: 0 1.25rem;\n\n @media screen and (min-width: 992px) {\n border-right: 1px solid #666;\n padding: 0;\n\n &:first-child a {\n padding-left: 0;\n }\n\n &:last-child {\n border-right: 0;\n\n a {\n padding-right: 0;\n }\n }\n }\n\n a {\n display: inline-block;\n font-size: 0.875rem;\n padding: 0.625rem;\n\n @media screen and (min-width: 992px) {\n display: inline;\n font-size: 0.75rem;\n padding: 0 0.75rem 0 0.625rem;\n }\n }\n }\n }\n}\n.custom_widget_CustomFooter_copyright_hp49n_495 {\n color: #dfdfdf;\n font-size: 1rem;\n margin-bottom: 0;\n\n @media screen and (min-width: 992px) {\n margin-bottom: 0.625rem;\n }\n}\n#custom_widget_CustomFooter_gsFooterSocial_hp49n_506,\n.custom_widget_CustomFooter_gsFooterSocial_hp49n_506 {\n background: #eaecef;\n padding: 0 calc(0.625rem + 0.3125rem);\n .custom_widget_CustomFooter_footerSocialItems_hp49n_509,\n #custom_widget_CustomFooter_footerSocialItems_hp49n_509 {\n text-align: center;\n\n @media screen and (min-width: 767px) {\n text-align: left;\n }\n }\n\n .custom_widget_CustomFooter_footerSocialItems_hp49n_509 ul,\n #custom_widget_CustomFooter_footerSocialItems_hp49n_509 ul {\n list-style-type: none;\n margin: auto;\n padding-left: 0;\n\n li {\n display: inline;\n margin: 0 0.625rem;\n }\n }\n}\n","tokens":{"footer-wrapper":"custom_widget_CustomFooter_footer-wrapper_hp49n_21","sr-only":"custom_widget_CustomFooter_sr-only_hp49n_34","footer":"custom_widget_CustomFooter_footer_hp49n_21","container":"custom_widget_CustomFooter_container_hp49n_52","row":"custom_widget_CustomFooter_row_hp49n_60","col":"custom_widget_CustomFooter_col_hp49n_74","col-xs-10":"custom_widget_CustomFooter_col-xs-10_hp49n_82","col-sm-10":"custom_widget_CustomFooter_col-sm-10_hp49n_83","col-xs-12":"custom_widget_CustomFooter_col-xs-12_hp49n_87","col-sm-4":"custom_widget_CustomFooter_col-sm-4_hp49n_88","col-sm-12":"custom_widget_CustomFooter_col-sm-12_hp49n_89","col-md-2":"custom_widget_CustomFooter_col-md-2_hp49n_90","col-md-8":"custom_widget_CustomFooter_col-md-8_hp49n_91","col-md-10":"custom_widget_CustomFooter_col-md-10_hp49n_92","col-md-12":"custom_widget_CustomFooter_col-md-12_hp49n_93","col-lg-2":"custom_widget_CustomFooter_col-lg-2_hp49n_94","col-lg-8":"custom_widget_CustomFooter_col-lg-8_hp49n_95","col-lg-12":"custom_widget_CustomFooter_col-lg-12_hp49n_96","col-lg-4":"custom_widget_CustomFooter_col-lg-4_hp49n_123","col-lg-10":"custom_widget_CustomFooter_col-lg-10_hp49n_133","pull-left":"custom_widget_CustomFooter_pull-left_hp49n_142","pad-bottom-20":"custom_widget_CustomFooter_pad-bottom-20_hp49n_156","pad-top-20":"custom_widget_CustomFooter_pad-top-20_hp49n_160","pad-top-30":"custom_widget_CustomFooter_pad-top-30_hp49n_164","pad-top-40":"custom_widget_CustomFooter_pad-top-40_hp49n_168","margin-left-20":"custom_widget_CustomFooter_margin-left-20_hp49n_174","margin-top-20":"custom_widget_CustomFooter_margin-top-20_hp49n_180","text-center":"custom_widget_CustomFooter_text-center_hp49n_186","text-right":"custom_widget_CustomFooter_text-right_hp49n_190","text-smaller":"custom_widget_CustomFooter_text-smaller_hp49n_194","text-small":"custom_widget_CustomFooter_text-small_hp49n_194","text-large":"custom_widget_CustomFooter_text-large_hp49n_199","footer-contact":"custom_widget_CustomFooter_footer-contact_hp49n_203","icon-gs-app":"custom_widget_CustomFooter_icon-gs-app_hp49n_221","gsi-icon-phone":"custom_widget_CustomFooter_gsi-icon-phone_hp49n_233","footer-link":"custom_widget_CustomFooter_footer-link_hp49n_245","footer-top-links":"custom_widget_CustomFooter_footer-top-links_hp49n_257","footer-top":"custom_widget_CustomFooter_footer-top_hp49n_257","footer-logo":"custom_widget_CustomFooter_footer-logo_hp49n_297","footer-list":"custom_widget_CustomFooter_footer-list_hp49n_305","dropup":"custom_widget_CustomFooter_dropup_hp49n_346","dropdown-menu":"custom_widget_CustomFooter_dropdown-menu_hp49n_359","footer-dropup-toggle":"custom_widget_CustomFooter_footer-dropup-toggle_hp49n_365","fa-angle-up":"custom_widget_CustomFooter_fa-angle-up_hp49n_370","footer-terms":"custom_widget_CustomFooter_footer-terms_hp49n_412","footer-terms-order-1":"custom_widget_CustomFooter_footer-terms-order-1_hp49n_431","footer-terms-order-2":"custom_widget_CustomFooter_footer-terms-order-2_hp49n_435","footer-bottom":"custom_widget_CustomFooter_footer-bottom_hp49n_441","footer-bottom-list-center":"custom_widget_CustomFooter_footer-bottom-list-center_hp49n_446","copyright":"custom_widget_CustomFooter_copyright_hp49n_495","gsFooterSocial":"custom_widget_CustomFooter_gsFooterSocial_hp49n_506","footerSocialItems":"custom_widget_CustomFooter_footerSocialItems_hp49n_509"}},"form":null},"localOverride":false},"CachedAsset:text:en_US-components/community/Breadcrumb-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/community/Breadcrumb-1738256407000","value":{"navLabel":"Breadcrumbs","dropdown":"Additional parent page navigation"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBanner-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBanner-1738256407000","value":{"messageMarkedAsSpam":"This post has been marked as spam","messageMarkedAsSpam@board:TKB":"This article has been marked as spam","messageMarkedAsSpam@board:BLOG":"This post has been marked as spam","messageMarkedAsSpam@board:FORUM":"This discussion has been marked as spam","messageMarkedAsSpam@board:OCCASION":"This event has been marked as spam","messageMarkedAsSpam@board:IDEA":"This idea has been marked as spam","manageSpam":"Manage Spam","messageMarkedAsAbuse":"This post has been marked as abuse","messageMarkedAsAbuse@board:TKB":"This article has been marked as abuse","messageMarkedAsAbuse@board:BLOG":"This post has been marked as abuse","messageMarkedAsAbuse@board:FORUM":"This discussion has been marked as abuse","messageMarkedAsAbuse@board:OCCASION":"This event has been marked as abuse","messageMarkedAsAbuse@board:IDEA":"This idea has been marked as abuse","preModCommentAuthorText":"This comment will be published as soon as it is approved","preModCommentModeratorText":"This comment is awaiting moderation","messageMarkedAsOther":"This post has been rejected due to other reasons","messageMarkedAsOther@board:TKB":"This article has been rejected due to other reasons","messageMarkedAsOther@board:BLOG":"This post has been rejected due to other reasons","messageMarkedAsOther@board:FORUM":"This discussion has been rejected due to other reasons","messageMarkedAsOther@board:OCCASION":"This event has been rejected due to other reasons","messageMarkedAsOther@board:IDEA":"This idea has been rejected due to other reasons","messageArchived":"This post was archived on {date}","relatedUrl":"View Related Content","relatedContentText":"Showing related content","archivedContentLink":"View Archived Content"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeActionButtonWidget-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeActionButtonWidget-1738256407000","value":{"defaultActionButtonTitle":"Start a Conversation","actionButton.grouphub.startDiscussion":"Start a Discussion","actionButton.title@board:FORUM":"Start a Discussion","actionButton.title@board:BLOG":"Create a Blog Post","actionButton.title@board:TKB":"Create an Article","actionButton.title@board:OCCASION":"Create an Event","actionButton.title@board:IDEA":"Suggest an Idea","joinGroupHub":"Join Group","join.successHeader":"Welcome","join.successMessage":"You are now a member of this group and are subscribed to updates.","errorMessage":"An unidentified problem occurred during the action you took. Please try again later.","errorHeader":"Error - Action Failed"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeInformationWidget-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeInformationWidget-1738256407000","value":{"WidgetTitle":"About {title}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/RelatedContentWidget-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/RelatedContentWidget-1738256407000","value":{"title":"Related Content","emptyDescription":"No content to show"},"localOverride":false},"CachedAsset:text:en_US-components/community/FooterWidget-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/community/FooterWidget-1738256407000","value":{"homeLink":"Community Home","topOfPage":"Top of Page","buildHash":"Build Hash:","buildNumber":"Build Number:","buildTime":"Build Time:","privacyPolicy":"Privacy Policy","helpLink":"Help"},"localOverride":false},"Category:category:RVTalk":{"__typename":"Category","id":"category:RVTalk","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"CATEGORY","displayId":"RVTalk","nodeType":"category","depth":1,"title":"Forums","shortTitle":"Forums"},"Forum:board:GetSupportAskQuestions":{"__typename":"Forum","id":"board:GetSupportAskQuestions","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:CommunityFeedback":{"__typename":"Forum","id":"board:CommunityFeedback","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Blog:board:Announcements_Blog":{"__typename":"Blog","id":"board:Announcements_Blog","blogPolicies":{"__typename":"BlogPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"User:user:23439":{"__typename":"User","id":"user:23439","uid":23439,"login":"Happy_Nana","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2021-10-24T17:05:48.000-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-3.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"messagesCount":3,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:feyqc97479/user:23439"},"AssociatedImage:{\"url\":\"https://community.goodsam.com/t5/s/feyqc97479/images/bi02NC01NThpNzc1RUQ2QTdCRUQzRkI1NQ\"}":{"__typename":"AssociatedImage","url":"https://community.goodsam.com/t5/s/feyqc97479/images/bi02NC01NThpNzc1RUQ2QTdCRUQzRkI1NQ","mimeType":"image/png"},"Forum:board:Campgrounds":{"__typename":"Forum","id":"board:Campgrounds","entityType":"FORUM","displayId":"Campgrounds","nodeType":"board","depth":2,"conversationStyle":"FORUM","title":"Campground 101","shortTitle":"Campground 101","parent":{"__ref":"Category:category:RVTalk"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://community.goodsam.com/t5/s/feyqc97479/images/bi02NC01NThpNzc1RUQ2QTdCRUQzRkI1NQ\"}"},"description":"Recommendations, reviews, and the inside scoop from fellow travelers.","eventPath":"category:RVTalk/community:feyqc97479board:Campgrounds/"},"ForumTopicMessage:message:3556469":{"__typename":"ForumTopicMessage","uid":3556469,"subject":"Newly Retired","id":"message:3556469","revisionNum":1,"repliesCount":29,"author":{"__ref":"User:user:23439"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:Campgrounds"},"conversation":{"__ref":"Conversation:conversation:3556469"},"moderationData":{"__ref":"ModerationData:moderation_data:3556469"},"postTime":"2021-10-24T17:10:25.000-07:00","lastPublishTime":"2021-10-24T17:10:25.000-07:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":7638},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:RVTalk/community:feyqc97479board:Campgrounds/message:3556469"},"Conversation:conversation:3556469":{"__typename":"Conversation","id":"conversation:3556469","solved":false,"topic":{"__ref":"ForumTopicMessage:message:3556469"},"lastPostingActivityTime":"2021-11-05T15:50:36.000-07:00","lastPostTime":"2021-11-05T15:50:36.000-07:00"},"ModerationData:moderation_data:3556469":{"__typename":"ModerationData","id":"moderation_data:3556469","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:3556469":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:3556469","relatedMessage":{"__ref":"ForumTopicMessage:message:3556469"}},"User:user:1837":{"__typename":"User","id":"user:1837","uid":1837,"login":"rwess","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2006-12-30T17:24:51.000-08:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-11.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"messagesCount":157,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:feyqc97479/user:1837"},"AssociatedImage:{\"url\":\"https://community.goodsam.com/t5/s/feyqc97479/images/bi04NS01NjNpM0UwNzEyQTNFMTUxM0NGMA\"}":{"__typename":"AssociatedImage","url":"https://community.goodsam.com/t5/s/feyqc97479/images/bi04NS01NjNpM0UwNzEyQTNFMTUxM0NGMA","mimeType":"image/png"},"Forum:board:RVTipsTricks":{"__typename":"Forum","id":"board:RVTipsTricks","entityType":"FORUM","displayId":"RVTipsTricks","nodeType":"board","depth":2,"conversationStyle":"FORUM","title":"RV Tips & Tricks","shortTitle":"RV Tips & Tricks","parent":{"__ref":"Category:category:RVTalk"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://community.goodsam.com/t5/s/feyqc97479/images/bi04NS01NjNpM0UwNzEyQTNFMTUxM0NGMA\"}"},"description":"Looking for advice before your next adventure? Look no further.","eventPath":"category:RVTalk/community:feyqc97479board:RVTipsTricks/"},"ForumTopicMessage:message:1154134":{"__typename":"ForumTopicMessage","uid":1154134,"subject":"Retirement","id":"message:1154134","revisionNum":1,"repliesCount":38,"author":{"__ref":"User:user:1837"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:RVTipsTricks"},"conversation":{"__ref":"Conversation:conversation:1154134"},"moderationData":{"__ref":"ModerationData:moderation_data:1154134"},"postTime":"2014-05-18T12:35:01.000-07:00","lastPublishTime":"2014-05-18T12:35:01.000-07:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":10490},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:RVTalk/community:feyqc97479board:RVTipsTricks/message:1154134"},"Conversation:conversation:1154134":{"__typename":"Conversation","id":"conversation:1154134","solved":false,"topic":{"__ref":"ForumTopicMessage:message:1154134"},"lastPostingActivityTime":"2014-07-03T19:30:59.000-07:00","lastPostTime":"2014-07-03T19:30:59.000-07:00"},"ModerationData:moderation_data:1154134":{"__typename":"ModerationData","id":"moderation_data:1154134","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:1154134":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:1154134","relatedMessage":{"__ref":"ForumTopicMessage:message:1154134"}},"User:user:287":{"__typename":"User","id":"user:287","uid":287,"login":"klr650goldwing","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2010-01-20T08:25:12.000-08:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-7.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"messagesCount":350,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:feyqc97479/user:287"},"GroupHub:grouphub:FifthWheel":{"__typename":"GroupHub","id":"grouphub:FifthWheel","entityType":"GROUP_HUB","displayId":"FifthWheel","nodeType":"grouphub","depth":2,"title":"Fifth Wheel Group","shortTitle":"Fifth Wheel Group"},"Forum:board:FifthWheelforum-board":{"__typename":"Forum","id":"board:FifthWheelforum-board","entityType":"FORUM","displayId":"FifthWheelforum-board","nodeType":"board","depth":3,"conversationStyle":"FORUM","title":"Fifth Wheel Group","shortTitle":"Forum","parent":{"__ref":"GroupHub:grouphub:FifthWheel"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":null,"description":"","eventPath":"grouphub:FifthWheel/category:TRAVELCENTER/community:feyqc97479board:FifthWheelforum-board/"},"ForumTopicMessage:message:2536196":{"__typename":"ForumTopicMessage","uid":2536196,"subject":"RETIREMENT","id":"message:2536196","revisionNum":1,"repliesCount":26,"author":{"__ref":"User:user:287"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:FifthWheelforum-board"},"conversation":{"__ref":"Conversation:conversation:2536196"},"moderationData":{"__ref":"ModerationData:moderation_data:2536196"},"postTime":"2017-01-01T09:32:43.000-08:00","lastPublishTime":"2017-01-01T09:32:43.000-08:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":5819},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"grouphub:FifthWheel/category:TRAVELCENTER/community:feyqc97479board:FifthWheelforum-board/message:2536196"},"Conversation:conversation:2536196":{"__typename":"Conversation","id":"conversation:2536196","solved":false,"topic":{"__ref":"ForumTopicMessage:message:2536196"},"lastPostingActivityTime":"2017-01-05T02:17:29.000-08:00","lastPostTime":"2017-01-05T02:17:29.000-08:00"},"ModerationData:moderation_data:2536196":{"__typename":"ModerationData","id":"moderation_data:2536196","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:2536196":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:2536196","relatedMessage":{"__ref":"ForumTopicMessage:message:2536196"}},"User:user:336022":{"__typename":"User","id":"user:336022","uid":336022,"login":"JohnES","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2004-10-14T20:21:59.000-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-3.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"messagesCount":22,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:feyqc97479/user:336022"},"ForumTopicMessage:message:1502078":{"__typename":"ForumTopicMessage","uid":1502078,"subject":"Retirement","id":"message:1502078","revisionNum":1,"repliesCount":20,"author":{"__ref":"User:user:336022"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:RVTipsTricks"},"conversation":{"__ref":"Conversation:conversation:1502078"},"moderationData":{"__ref":"ModerationData:moderation_data:1502078"},"postTime":"2014-12-03T21:10:21.000-08:00","lastPublishTime":"2014-12-03T21:10:21.000-08:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":7834},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:RVTalk/community:feyqc97479board:RVTipsTricks/message:1502078"},"Conversation:conversation:1502078":{"__typename":"Conversation","id":"conversation:1502078","solved":false,"topic":{"__ref":"ForumTopicMessage:message:1502078"},"lastPostingActivityTime":"2014-12-11T12:21:07.000-08:00","lastPostTime":"2014-12-11T12:21:07.000-08:00"},"ModerationData:moderation_data:1502078":{"__typename":"ModerationData","id":"moderation_data:1502078","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:1502078":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:1502078","relatedMessage":{"__ref":"ForumTopicMessage:message:1502078"}},"User:user:144933":{"__typename":"User","id":"user:144933","uid":144933,"login":"barbandwayne","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2007-02-20T08:26:32.000-08:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-2.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"messagesCount":191,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:feyqc97479/user:144933"},"GroupHub:grouphub:FullTimeRVers":{"__typename":"GroupHub","id":"grouphub:FullTimeRVers","entityType":"GROUP_HUB","displayId":"FullTimeRVers","nodeType":"grouphub","depth":2,"title":"Full Time RVers","shortTitle":"Full Time RVers"},"Forum:board:FullTimeRVersforum-board":{"__typename":"Forum","id":"board:FullTimeRVersforum-board","entityType":"FORUM","displayId":"FullTimeRVersforum-board","nodeType":"board","depth":3,"conversationStyle":"FORUM","title":"Full Time RVers","shortTitle":"Forum","parent":{"__ref":"GroupHub:grouphub:FullTimeRVers"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":null,"description":"","eventPath":"grouphub:FullTimeRVers/category:TRAVELCENTER/community:feyqc97479board:FullTimeRVersforum-board/"},"ForumTopicMessage:message:2123077":{"__typename":"ForumTopicMessage","uid":2123077,"subject":"Retirement","id":"message:2123077","revisionNum":1,"repliesCount":25,"author":{"__ref":"User:user:144933"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:FullTimeRVersforum-board"},"conversation":{"__ref":"Conversation:conversation:2123077"},"moderationData":{"__ref":"ModerationData:moderation_data:2123077"},"postTime":"2016-02-15T11:52:03.000-08:00","lastPublishTime":"2016-02-15T11:52:03.000-08:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":4115},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"grouphub:FullTimeRVers/category:TRAVELCENTER/community:feyqc97479board:FullTimeRVersforum-board/message:2123077"},"Conversation:conversation:2123077":{"__typename":"Conversation","id":"conversation:2123077","solved":false,"topic":{"__ref":"ForumTopicMessage:message:2123077"},"lastPostingActivityTime":"2016-02-17T06:02:55.000-08:00","lastPostTime":"2016-02-17T06:02:55.000-08:00"},"ModerationData:moderation_data:2123077":{"__typename":"ModerationData","id":"moderation_data:2123077","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:2123077":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:2123077","relatedMessage":{"__ref":"ForumTopicMessage:message:2123077"}},"QueryVariables:TopicReplyList:message:2110800:1":{"__typename":"QueryVariables","id":"TopicReplyList:message:2110800:1","value":{"id":"message:2110800","first":10,"after":"MjQuMTJ8Mi4xfGl8MTB8Mzk6MHxpbnQsMjExMDgxOSwyMTEwODEw","sorts":{"postTime":{"direction":"DESC"}},"repliesFirst":3,"repliesFirstDepthThree":1,"repliesSorts":{"postTime":{"direction":"DESC"}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":true,"useBody":true,"useKudosCount":true,"useTimeToRead":false,"useMedia":false,"useReadOnlyIcon":false,"useRepliesCount":true,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":false,"attachmentsFirst":5,"useTags":true,"useNodeAncestors":false,"useUserHoverCard":false,"useNodeHoverCard":false,"useModerationStatus":true,"usePreviewSubjectModal":false,"useMessageStatus":true}},"ROOT_MUTATION":{"__typename":"Mutation"},"CachedAsset:text:en_US-components/community/Navbar-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/community/Navbar-1738256407000","value":{"community":"Community Home","inbox":"Inbox","manageContent":"Manage Content","tos":"Terms of Service","forgotPassword":"Forgot Password","themeEditor":"Theme Editor","edit":"Edit Navigation Bar","skipContent":"Skip to content","rv-owners-link":"RV Owner Groups","groups-link":"Groups","migrated-link-7":"Good Sam Home ","community-feedback-link":"Community Feedback","migrated-link-8":"My Rewards","Common-community-feedback-link":"Community Feedback","migrated-link-1":"Groups","customer-support-link-1":"Customer Support","Common-announcements_blog-link":"Announcements","customer-support-link":"Resources","Common-get-support-ask-questions-link":"Customer Support","migrated-link-0":"Forums","migrated-link-3":"Resources","announcements_blog-link":"Announcements","r-v-t-e-c-h-link":"Test ","Common-admin-mods-private-link":"Admin & Mods (Private)","fifth-wheelsforum-board-link":"Fifth Wheels Owners","events-link":"Events","external-link":"Good Sam Home"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarHamburgerDropdown-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarHamburgerDropdown-1738256407000","value":{"hamburgerLabel":"Side Menu"},"localOverride":false},"CachedAsset:text:en_US-components/community/BrandLogo-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/community/BrandLogo-1738256407000","value":{"logoAlt":"Khoros","themeLogoAlt":"Brand Logo"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarTextLinks-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarTextLinks-1738256407000","value":{"more":"More"},"localOverride":false},"CachedAsset:text:en_US-components/search/SpotlightSearchIcon-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/search/SpotlightSearchIcon-1738256407000","value":{"search":"Search"},"localOverride":false},"CachedAsset:text:en_US-components/authentication/AuthenticationLink-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/authentication/AuthenticationLink-1738256407000","value":{"title.login":"Sign In or Register","title.registration":"Register","title.forgotPassword":"Forgot Password","title.multiAuthLogin":"Sign In or Register"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeLink-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeLink-1738256407000","value":{"place":"Place {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewStandard-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewStandard-1738256407000","value":{"anonymous":"Anonymous","author":"{messageAuthorLogin}","authorBy":"{messageAuthorLogin}","board":"{messageBoardTitle}","replyToUser":" to {parentAuthor}","showMoreReplies":"Show More","replyText":"Reply","repliesText":"Replies","markedAsSolved":"Marked as Solved","movedMessagePlaceholder.BLOG":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.TKB":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.FORUM":"{count, plural, =0 {This reply has been} other {These replies have been} }","movedMessagePlaceholder.IDEA":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.OCCASION":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholderUrlText":"moved.","messageStatus":"Status: ","statusChanged":"Status changed: {previousStatus} to {currentStatus}","statusAdded":"Status added: {status}","statusRemoved":"Status removed: {status}","labelExpand":"expand replies","labelCollapse":"collapse replies","unhelpfulReason.reason1":"Content is outdated","unhelpfulReason.reason2":"Article is missing information","unhelpfulReason.reason3":"Content is for a different Product","unhelpfulReason.reason4":"Doesn't match what I was searching for"},"localOverride":false},"CachedAsset:text:en_US-components/messages/ThreadedReplyList-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/ThreadedReplyList-1738256407000","value":{"title":"{count, plural, one{# Reply} other{# Replies}}","title@board:BLOG":"{count, plural, one{# Comment} other{# Comments}}","title@board:TKB":"{count, plural, one{# Comment} other{# Comments}}","title@board:IDEA":"{count, plural, one{# Comment} other{# Comments}}","title@board:OCCASION":"{count, plural, one{# Comment} other{# Comments}}","noRepliesTitle":"No Replies","noRepliesTitle@board:BLOG":"No Comments","noRepliesTitle@board:TKB":"No Comments","noRepliesTitle@board:IDEA":"No Comments","noRepliesTitle@board:OCCASION":"No Comments","noRepliesDescription":"Be the first to reply","noRepliesDescription@board:BLOG":"Be the first to comment","noRepliesDescription@board:TKB":"Be the first to comment","noRepliesDescription@board:IDEA":"Be the first to comment","noRepliesDescription@board:OCCASION":"Be the first to comment","messageReadOnlyAlert:BLOG":"Comments have been turned off for this post","messageReadOnlyAlert:TKB":"Comments have been turned off for this article","messageReadOnlyAlert:IDEA":"Comments have been turned off for this idea","messageReadOnlyAlert:FORUM":"Replies have been turned off for this discussion","messageReadOnlyAlert:OCCASION":"Comments have been turned off for this event"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyCallToAction-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyCallToAction-1738256407000","value":{"leaveReply":"Leave a reply...","leaveReply@board:BLOG@message:root":"Leave a comment...","leaveReply@board:TKB@message:root":"Leave a comment...","leaveReply@board:IDEA@message:root":"Leave a comment...","leaveReply@board:OCCASION@message:root":"Leave a comment...","repliesTurnedOff.FORUM":"Replies are turned off for this topic","repliesTurnedOff.BLOG":"Comments are turned off for this topic","repliesTurnedOff.TKB":"Comments are turned off for this topic","repliesTurnedOff.IDEA":"Comments are turned off for this topic","repliesTurnedOff.OCCASION":"Comments are turned off for this topic","infoText":"Stop poking me!"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/QueryHandler-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/QueryHandler-1738256407000","value":{"title":"Query Handler"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/BuildInformation-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/BuildInformation-1738256407000","value":{"buildHash":"Build Hash: {buildHash}","buildNumber":"Build Number: {buildNumber}","buildTime":"Build Time: {buildTime}"},"localOverride":false},"CachedAsset:text:en_US-components/community/KhorosLogo-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/community/KhorosLogo-1738256407000","value":{"alt":"Powered By Khoros"},"localOverride":false},"User:user:49005":{"__typename":"User","id":"user:49005","uid":49005,"login":"Heap64","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2014-03-28T18:47:48.000-07:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-11.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"entityType":"USER","eventPath":"community:feyqc97479/user:49005"},"ModerationData:moderation_data:2110809":{"__typename":"ModerationData","id":"moderation_data:2110809","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:2110809":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:49005"},"id":"message:2110809","revisionNum":1,"uid":2110809,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TravelTrailerforum-board"},"parent":{"__ref":"ForumTopicMessage:message:2110800"},"conversation":{"__ref":"Conversation:conversation:2110800"},"subject":"Re: TT for retirement use","moderationData":{"__ref":"ModerationData:moderation_data:2110809"},"body":"We like our Arctic Fox 25Y and think it could fit the bill at 30' I would suggest upgrading the couch or 2 chairs for extended use. We have the standard jack-knife and it is fine for our use now, but I wouldn't want to sit in it everyday. The bedroom/bath layout is great for two people.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2016-01-26T13:28:24.000-08:00","lastPublishTime":"2016-01-26T13:28:24.000-08:00","metrics":{"__typename":"MessageMetrics","views":504},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"grouphub:TravelTrailer/category:TRAVELCENTER/community:feyqc97479board:TravelTrailerforum-board/message:2110800/message:2110809","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"User:user:120418":{"__typename":"User","id":"user:120418","uid":120418,"login":"carringb","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2003-07-28T08:06:50.000-07:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-11.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"entityType":"USER","eventPath":"community:feyqc97479/user:120418"},"ModerationData:moderation_data:2110808":{"__typename":"ModerationData","id":"moderation_data:2110808","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:2110808":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:120418"},"id":"message:2110808","revisionNum":1,"uid":2110808,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TravelTrailerforum-board"},"parent":{"__ref":"ForumTopicMessage:message:2110800"},"conversation":{"__ref":"Conversation:conversation:2110800"},"subject":"Re: TT for retirement use","moderationData":{"__ref":"ModerationData:moderation_data:2110808"},"body":"For that kind of use, I would definitely stick with Arctic Fox, or any other Northwood brand. ORV is a close 2nd (I have one) but AF-Nash still uses better components in some areas, since the price point is slightly higher. Stuff like slideout drives and leveling jacks are just higher-end and more durable. I've had to swap out all my jacks (factory swapped the upgraded the tongue jack under warranty) and I still worry about the longevity of the Schwintek system on my slide-outs. Said slide system resulted a couple visits to the factory (they did the pickup!) and its great having their excellent warranty support, but it would have been better if those visits weren't needed.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2016-01-26T08:34:46.000-08:00","lastPublishTime":"2016-01-26T08:34:46.000-08:00","metrics":{"__typename":"MessageMetrics","views":504},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"grouphub:TravelTrailer/category:TRAVELCENTER/community:feyqc97479board:TravelTrailerforum-board/message:2110800/message:2110808","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"User:user:245348":{"__typename":"User","id":"user:245348","uid":245348,"login":"path1","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2012-04-19T22:06:41.000-07:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-6.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"entityType":"USER","eventPath":"community:feyqc97479/user:245348"},"ModerationData:moderation_data:2110807":{"__typename":"ModerationData","id":"moderation_data:2110807","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:2110807":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:245348"},"id":"message:2110807","revisionNum":1,"uid":2110807,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TravelTrailerforum-board"},"parent":{"__ref":"ForumTopicMessage:message:2110800"},"conversation":{"__ref":"Conversation:conversation:2110800"},"subject":"Re: TT for retirement use","moderationData":{"__ref":"ModerationData:moderation_data:2110807"},"body":"
I would appreciate input from anyone with like experience.
Sounds like us... MINUS the \"snow areas\" unless just passing thru. That length is working out pretty good, for us over all. But not perfect. But what set up is? To big for some forest campgrounds (with tow vehicle about 60 foot) But large enough to be comfortable on long trips. We also have an older class C that is a great travelling machine but to small (for us) on longer trips. So TT has worked out great for us. Wife found trailer used, a two year old Arctic Fox, hardly used and she honed in on. Owned for 2 years now. Arctic Fox is a lot better than any other RV we've owned. Little things that are not so noticeable with Arctic Fox until you live in them awhile. Arctic Fox are heavy though. Add to whatever ad's say. Our tow rig is older (2001) 2500 CTD. So had to add a few things like air bags, bigger mirrors, and few other minor things. (A few must haves IMO) If you don't have exhaust brake, I would highly consider one. I go from Canadian border to LA and not one mountain pass have I had to worry about brakes. And a good set of gauges. Pyro gauge and trans gauge most important. And a deep trans pan, Used to have trans temp of around 210 which is OK but on long hills, temps used to creep up. Now with deep dish trans pan temp hasn't gone over 190 on steepest hills in the west and in summer. With the pyro gauge, when I pull a hill I just blend in with other traffic when gauge hits 1200 I back off a little and keep it there. Works out fine for us.
I'm thinking on 30ft max for the TT and price up to $45000
Sounds like you're going new, if so a few options are really worth while. Keep in mind that any RV takes maintenance regardless of manufacture.
You might want to explore. http://www.nroa2003.com/forum/
When exploring keep in mind how many actual postings are problem compared to people making mods or self imposed problems due to lack of maintenance. I think Northwoods has a good design compared to others but they are still put together by humans, so you still have problems. One thing Northwoods does to prevent problems... every unit sold, some money goes into their profit sharing fund. But money comes out of that fund when they have to pay for mistakes. Hard to get a quality unit in todays times. Trying not to be an advertisement for them. When we were looking for a replacement RV, we found very few NW owners that had any major complaints. Many were second and third owners after owning other brands. We talked with maybe 30 or 40 owners before buying. Heard more complaints from camper owners than TT or 5th wheel owners for some reason. I am Not in love with their part process AT ALL. Takes on average 3 weeks for some model specific parts. Like a small trim piece.
Someone else said
Good ground clearance for the TT. Look for one where the axles can be adjusted (flipped)
Mine rides high enough that I installed a fence post sewer tube on the metal things that hit the drive way. Never scrapped. 29 inches to top of hitch ball. Actually barley clears tailgate when I open tailgate (2 wheel drive) Not in love with TT axles but no problems yet.
Hope this helps.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2016-01-26T08:10:35.000-08:00","lastPublishTime":"2016-01-26T08:10:35.000-08:00","metrics":{"__typename":"MessageMetrics","views":505},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"grouphub:TravelTrailer/category:TRAVELCENTER/community:feyqc97479board:TravelTrailerforum-board/message:2110800/message:2110807","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"User:user:136431":{"__typename":"User","id":"user:136431","uid":136431,"login":"WyoTraveler","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2011-11-22T05:21:29.000-08:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-1.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"entityType":"USER","eventPath":"community:feyqc97479/user:136431"},"ModerationData:moderation_data:2110806":{"__typename":"ModerationData","id":"moderation_data:2110806","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:2110806":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:136431"},"id":"message:2110806","revisionNum":1,"uid":2110806,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TravelTrailerforum-board"},"parent":{"__ref":"ForumTopicMessage:message:2110800"},"conversation":{"__ref":"Conversation:conversation:2110800"},"subject":"Re: TT for retirement use","moderationData":{"__ref":"ModerationData:moderation_data:2110806"},"body":"
goducks10 wrote:
JMHO but I'd look at http://outdoorsrvmfg.com/. They're a spin off of Northwood MFG. Their new site shows that they now include dual pane windows on all but one model. The have larger tanks than Arctic Fox. Same in house built frame. Plus they have a better warranty.
I looked at their web site. Looks like some pretty impressive features. Even the dump valves are protected.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2016-01-26T07:40:04.000-08:00","lastPublishTime":"2016-01-26T07:40:04.000-08:00","metrics":{"__typename":"MessageMetrics","views":504},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"grouphub:TravelTrailer/category:TRAVELCENTER/community:feyqc97479board:TravelTrailerforum-board/message:2110800/message:2110806","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"User:user:258295":{"__typename":"User","id":"user:258295","uid":258295,"login":"Sam_Spade","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2015-11-05T06:28:59.000-08:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-7.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"entityType":"USER","eventPath":"community:feyqc97479/user:258295"},"ModerationData:moderation_data:2110805":{"__typename":"ModerationData","id":"moderation_data:2110805","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:2110805":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:258295"},"id":"message:2110805","revisionNum":1,"uid":2110805,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TravelTrailerforum-board"},"parent":{"__ref":"ForumTopicMessage:message:2110800"},"conversation":{"__ref":"Conversation:conversation:2110800"},"subject":"Re: TT for retirement use","moderationData":{"__ref":"ModerationData:moderation_data:2110805"},"body":"
TexasChaps wrote:
Hello,
I'm looking for suggestions on an RV for our retirement.
Only YOU (two) can really determine what kind of environment you NEED to be comfortable and happy.
To that end, a rental or two might be an extremely good investment.....unless you have \"camped\" before.
The rentals do not have to be a pull behind like you are thinking about. I'm not sure you can even rent an actual trailer like that.
The only comment I have up front is about the word \"snow\" in your list of potential destinations. If you venture to a place where it goes below freezing at night, you have a whole extra bunch of things to be concerned with.....like freezing pipes and using up all your propane for heat. NOT A GOOD PLAN for most people.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2016-01-26T07:18:11.000-08:00","lastPublishTime":"2016-01-26T07:18:11.000-08:00","metrics":{"__typename":"MessageMetrics","views":128},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"grouphub:TravelTrailer/category:TRAVELCENTER/community:feyqc97479board:TravelTrailerforum-board/message:2110800/message:2110805","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"Rank:rank:40":{"__typename":"Rank","id":"rank:40","position":31,"name":"Explorer III","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:120677":{"__typename":"User","id":"user:120677","uid":120677,"login":"aftermath","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2005-09-18T20:05:57.000-07:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-10.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:40"},"entityType":"USER","eventPath":"community:feyqc97479/user:120677"},"ModerationData:moderation_data:2110804":{"__typename":"ModerationData","id":"moderation_data:2110804","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:2110804":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:120677"},"id":"message:2110804","revisionNum":1,"uid":2110804,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TravelTrailerforum-board"},"parent":{"__ref":"ForumTopicMessage:message:2110800"},"conversation":{"__ref":"Conversation:conversation:2110800"},"subject":"Re: TT for retirement use","moderationData":{"__ref":"ModerationData:moderation_data:2110804"},"body":"I will second the Arctic Fox comment. I do not have one buy by cousin does and it is a very well built trailer and as solid as I have seen. It also is heavy which is probably why it feels that way. With your TV this won't be an issue.
\"Boondocking\" means a lot of things to a lot of different people. If you are going to be living in it for 8 months at a time I would say get a big one, the bigger the better actually. If you plan to park in a place where you don't have hookups then I wouldn't get all worked up about clearance. My cousin's Arctic Fox has a lot of clearance, more than I like actually as I think there are 3 or 4 steps to get into the cabin.
If you are going to drag this up mountain logging roads and out through the trees then clearance will be a big issue. I would never buy a trailer and then flip the axles unless that was all I could afford.
Northwoods Manufacturing make a number of trailers that have cold weather advantages. Look for thermal windows and a covered insulated belly pan and ducted air. My cousin's Arctic Fox has a great AC system that keeps it cool and is very quiet.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2016-01-26T07:10:33.000-08:00","lastPublishTime":"2016-01-26T07:10:33.000-08:00","metrics":{"__typename":"MessageMetrics","views":98},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"grouphub:TravelTrailer/category:TRAVELCENTER/community:feyqc97479board:TravelTrailerforum-board/message:2110800/message:2110804","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"Rank:rank:41":{"__typename":"Rank","id":"rank:41","position":33,"name":"Explorer II","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:1762":{"__typename":"User","id":"user:1762","uid":1762,"login":"rbpru","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2013-12-18T15:07:24.000-08:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-11.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:41"},"entityType":"USER","eventPath":"community:feyqc97479/user:1762"},"ModerationData:moderation_data:2110803":{"__typename":"ModerationData","id":"moderation_data:2110803","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:2110803":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:1762"},"id":"message:2110803","revisionNum":1,"uid":2110803,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TravelTrailerforum-board"},"parent":{"__ref":"ForumTopicMessage:message:2110800"},"conversation":{"__ref":"Conversation:conversation:2110800"},"subject":"Re: TT for retirement use","moderationData":{"__ref":"ModerationData:moderation_data:2110803"},"body":"My first question is have you done this before?
If you are a boondocker and used to long weeks on the road then you know the ropes. If not it might not be as expected.
I find my TT travel limit is about 6 weeks and my wilderness canoe camping about a week.
I enjoy both my travel time and my time at home.
Good luck","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2016-01-26T07:03:58.000-08:00","lastPublishTime":"2016-01-26T07:03:58.000-08:00","metrics":{"__typename":"MessageMetrics","views":98},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"grouphub:TravelTrailer/category:TRAVELCENTER/community:feyqc97479board:TravelTrailerforum-board/message:2110800/message:2110803","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"User:user:199429":{"__typename":"User","id":"user:199429","uid":199429,"login":"goducks10","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2010-02-22T08:06:49.000-08:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-12.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"entityType":"USER","eventPath":"community:feyqc97479/user:199429"},"ModerationData:moderation_data:2110802":{"__typename":"ModerationData","id":"moderation_data:2110802","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:2110802":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:199429"},"id":"message:2110802","revisionNum":1,"uid":2110802,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TravelTrailerforum-board"},"parent":{"__ref":"ForumTopicMessage:message:2110800"},"conversation":{"__ref":"Conversation:conversation:2110800"},"subject":"Re: TT for retirement use","moderationData":{"__ref":"ModerationData:moderation_data:2110802"},"body":"JMHO but I'd look at http://outdoorsrvmfg.com/. They're a spin off of Northwood MFG. Their new site shows that they now include dual pane windows on all but one model. The have larger tanks than Arctic Fox. Same in house built frame. Plus they have a better warranty.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2016-01-26T07:01:37.000-08:00","lastPublishTime":"2016-01-26T07:01:37.000-08:00","metrics":{"__typename":"MessageMetrics","views":98},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"grouphub:TravelTrailer/category:TRAVELCENTER/community:feyqc97479board:TravelTrailerforum-board/message:2110800/message:2110802","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"User:user:147700":{"__typename":"User","id":"user:147700","uid":147700,"login":"the_bear_II","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2008-02-14T09:47:30.000-08:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-10.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"entityType":"USER","eventPath":"community:feyqc97479/user:147700"},"ModerationData:moderation_data:2110801":{"__typename":"ModerationData","id":"moderation_data:2110801","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:2110801":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:147700"},"id":"message:2110801","revisionNum":1,"uid":2110801,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TravelTrailerforum-board"},"parent":{"__ref":"ForumTopicMessage:message:2110800"},"conversation":{"__ref":"Conversation:conversation:2110800"},"subject":"Re: TT for retirement use","moderationData":{"__ref":"ModerationData:moderation_data:2110801"},"body":"A Few things I look for:
A floorplan that provides space for two people to move past each other no bottlenecks.
A Floorplan that provides comfortable seating (Recliners) and space for each of you to have some alone time just in case the weather gets bad for a few days and you're stuck inside. Cabin fevers comes on quick.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2016-01-26T06:32:18.000-08:00","lastPublishTime":"2016-01-26T06:32:18.000-08:00","metrics":{"__typename":"MessageMetrics","views":98},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"grouphub:TravelTrailer/category:TRAVELCENTER/community:feyqc97479board:TravelTrailerforum-board/message:2110800/message:2110801","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"CachedAsset:text:en_US-components/community/NavbarDropdownToggle-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarDropdownToggle-1738256407000","value":{"ariaLabelClosed":"Press the down arrow to open the menu"},"localOverride":false},"CachedAsset:text:en_US-components/messages/EscalatedMessageBanner-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/EscalatedMessageBanner-1738256407000","value":{"escalationMessage":"Escalated to Salesforce by {username} on {date}","viewDetails":"View Details","modalTitle":"Case Details","escalatedBy":"Escalated by: ","escalatedOn":"Escalated on: ","caseNumber":"Case Number: ","status":"Status: ","lastUpdateDate":"Last Update: ","automaticEscalation":"automatic escalation","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-components/users/UserLink-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/users/UserLink-1738256407000","value":{"authorName":"View Profile: {author}","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/users/UserRank-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserRank-1738256407000","value":{"rankName":"{rankName}","userRank":"Author rank {rankName}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageTime-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageTime-1738256407000","value":{"postTime":"Published: {time}","lastPublishTime":"Last Update: {time}","conversation.lastPostingActivityTime":"Last posting activity time: {time}","conversation.lastPostTime":"Last post time: {time}","moderationData.rejectTime":"Rejected time: {time}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSolvedBadge-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSolvedBadge-1738256407000","value":{"solved":"Solved"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSubject-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSubject-1738256407000","value":{"noSubject":"(no subject)"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBody-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBody-1738256407000","value":{"showMessageBody":"Show More","mentionsErrorTitle":"{mentionsType, select, board {Board} user {User} message {Message} other {}} No Longer Available","mentionsErrorMessage":"The {mentionsType} you are trying to view has been removed from the community.","videoProcessing":"Video is being processed. Please try again in a few minutes.","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageCustomFields-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageCustomFields-1738256407000","value":{"CustomField.default.label":"Value of {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyButton-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyButton-1738256407000","value":{"repliesCount":"{count}","title":"Reply","title@board:BLOG@message:root":"Comment","title@board:TKB@message:root":"Comment","title@board:IDEA@message:root":"Comment","title@board:OCCASION@message:root":"Comment"},"localOverride":false},"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/AcceptedSolutionButton-1738256407000","value":{"accept":"Mark as Solution","accepted":"Marked as Solution","errorHeader":"Error!","errorAdd":"There was an error marking as solution.","errorRemove":"There was an error unmarking as solution.","solved":"Solved"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeView/NodeViewCard-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeView/NodeViewCard-1738256407000","value":{"title":"{nodeTitle} ","creationDate":"Created: {creationDate}","ownedBy":"Owned by: {owners}{text}","showOwnerListText":", and {ownersCount} more","unreadCount":"{count} unread","nodeViewDrawerBtn":"Node view drawer for {place}","drawerActionTooltip":"Show category children"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewInline-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewInline-1738256407000","value":{"bylineAuthor":"{bylineAuthor}","bylineBoard":"{bylineBoard}","anonymous":"Anonymous","place":"Place {bylineBoard}","gotoParent":"Go to parent {name}"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserAvatar-1738256407000","value":{"altText":"{login}'s avatar","altTextGeneric":"User's avatar"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/ranks/UserRankLabel-1738256407000","value":{"altTitle":"Icon for {rankName} rank"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeTopicsCount-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeTopicsCount-1738256407000","value":{"topicCount":"{count}","topicCountWithNeutralLabel@board:OCCASION":"{count, plural, one{# Event} other{# Events}}","topicCountWithNeutralLabel":"{count, plural, one{# Post} other{# Posts}}","topicCount@board:FORUM":"{count, plural, one{# Post} other{# Posts}}","topicCount@board:BLOG":"{count, plural, one{# Post} other{# Posts}}","topicCount@board:CONTEST":"{count, plural, one{# Entry} other{# Entries}}","topicCount@board:GROUP":"{count, plural, one{# Topic} other{# Topics}}","topicCount@board:IDEA":"{count, plural, one{# Idea} other{# Ideas}}","topicCount@board:QANDA":"{count, plural, one{# Question} other{# Questions}}","topicCount@board:TKB":"{count, plural, one{# Article} other{# Articles}}","topicCount@board:OCCASION":"{count, plural, one{# Event} other{# Events}}","title":"{count, plural,one { Post} other{ Posts}}"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeLatestActivityTime-1738256407000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeLatestActivityTime-1738256407000","value":{"title":"Latest Activity: {latestActivityTime}","updatedAt":"Updated {latestActivityTime}","noActivity":"No activity yet"},"localOverride":false}}}},"page":"/forums/ForumMessagePage/ForumMessagePage","query":{"after":"MjQuMTJ8Mi4xfGl8MTB8Mzk6MHxpbnQsMjExMDgxOSwyMTEwODEw","boardId":"traveltrailerforum-board","messageSubject":"tt-for-retirement-use","messageId":"2110800"},"buildId":"UtG3-Pbti3STtL2t_tPEH","runtimeConfig":{"buildInformationVisible":false,"logLevelApp":"info","logLevelMetrics":"info","openTelemetryClientEnabled":false,"openTelemetryConfigName":"campingworld","openTelemetryServiceVersion":"25.1.0","openTelemetryUniverse":"prod","openTelemetryCollector":"http://localhost:4318","openTelemetryRouteChangeAllowedTime":"5000","apolloDevToolsEnabled":false,"inboxMuteWipFeatureEnabled":false},"isFallback":false,"isExperimentalCompile":false,"dynamicIds":["./components/seo/QAPageSchema/QAPageSchema.tsx","./components/community/Navbar/NavbarWidget.tsx","./components/community/Breadcrumb/BreadcrumbWidget.tsx","./components/messages/TopicWithThreadedReplyListWidget/TopicWithThreadedReplyListWidget.tsx","./components/nodes/NodeActionButtonWidget/NodeActionButtonWidget.tsx","./components/nodes/NodeInformationWidget/NodeInformationWidget.tsx","./components/messages/RelatedContentWidget/RelatedContentWidget.tsx","./components/customComponent/CustomComponent/CustomComponent.tsx","./components/community/FooterWidget/FooterWidget.tsx","./components/messages/MessageView/MessageViewStandard/MessageViewStandard.tsx","./components/messages/ThreadedReplyList/ThreadedReplyList.tsx","./components/community/FooterWidgetHelpLink/FooterWidgetHelpLink.tsx","./components/community/KhorosLogo/KhorosLogo.tsx","../shared/client/components/common/List/UnstyledList/UnstyledList.tsx","./components/messages/MessageView/MessageView.tsx","./components/nodes/NodeView/NodeView.tsx","./components/nodes/NodeView/NodeViewCard/NodeViewCard.tsx","./components/messages/MessageView/MessageViewInline/MessageViewInline.tsx"],"appGip":true,"scriptLoader":[]}
