RoyB wrote:
Only thing i can think of now then is one of those surge protectors you might be using... Not familiar with any of those in the circuits... Have never used one before...
I'm guessing if you plug the circuit tester inside the trailer 120VAC receptacle they must be reading a open ground perhaps...
Doing what you have done would have solved the problem if it was my more simple OFF-ROAD POPUP trailer haha...
My shore power cable ties directly into my Converter 120VAC Power Distribution panel where all of the HOT, NEUTRAL, and GROUND connections are at...
Roy Ken
Thanks Roy. There are no surge protectors plugged in. I've removed everything from all of the outlets. The shore power on this unit goes to a main breaker and then the converter is powered from an secondary breaker. I guess I'll start pulling outlets to see if I can find the issue. 73's
Travis
K1TRM
