itguy08 wrote:
This is interesting to me as well.  Got the truck - 2011 F150 Ecoboost, SuperCrew, Max Tow, 5' bed, 145" WB. Plenty of payload at 1820.
Now searching for the trailer to pull behind it.  Plenty under weight in the 30-35ft range and wondering if there is a practical length as most say go by the weight and payload will be the limiting factor.
No issues buying a good WD hitch with good sway control if that's what it takes.
You will find no manufacturer that limits the length of a trailer, only the weight. You will run out of weight long before you run out of Wheelbase.
My 150 has a 145" Wheelbase. Longer in fact than many 2500s, and 250s. I tow a 31 foot TT. I have absolutely no sway. Big trucks do not push me around, and in fact I have several times forgotten to install the sway control bar. Still no sway, and no problems from trucks. With the proper tires, and with the WDH adjusted correctly, The TT does not move the truck around at all. If it were not for the engine working a little harder, I could forget it is there.
Yes I can feel a strong cross wind. But EVERY vehicle on the road can feel it as well.
