Saltlick
13 years agoExplorer
TT Newbie has questions, help?
Hello,
Just got a skyline 2002 249LT and I am a little confused in regards to the water heater. So if im at home, and hook up the water hose to my trailer (in the city water connection) and turn the water hose on this will fill up my water heater correct? And once its full (you check by turning on the hot water faucet, if water comes out then its full) i can then hook up electricity and turn on the switch to ignite the water heater and all is right in the world.Correct?
I guess i am just checking to see if the above is the right way to do it, and my other question is once that is done, and i unhook the city water line does the 6 gallons of water remain in the water heater tank, so from that point on i can just leave the power cord hooked up to it at home and do what im going to do in the trailer and not worry about the hot water tank burning up? I guess im confused, ive heard you cant plug in your trailer to your house without the hot water heater being filled up, even if you dont plan on hitting the switch to ignite the gas and heat the water up. Is there a heating element in the tank that comes on the minute you plug in the power somewhere?
Oh and one more thing, when you guys go camping and hook up to the city water and electricity, do you just turn your propane on and leave it on the whole time your camping? Do you drain the 6 gallons of water out of the water heater before you leave for camping or just leave that water in there until your ready to winterize it? Sorry about the long post, i just want to get this right! So many questions so little time to camp in cold oregon.
