dtzackus
Apr 13, 2013Explorer
Rule #1, never turn on a water heater unless it is full of water, those heating elements will burn out very quickly if not water is there.
Once you connect to the city water part of your camper, I would turn on the hot water till all the air comes out of the line (the 6 gallons) then you are ok to turn on your heater. It typically takes 20 minutes on propane to heat the water up. The water heater will only turn on if you turn the switch on, plus you will have to turn on the propane, not sure how the electric ones work (never had one)
I always dump the water before I leave the camp site, why tug an extra 48 lbs (6 gallons at 8 lbs each). I typically drain all water before we leave.
When we 1st started camping, I would always turn on the gas when I needed it, then turn it off when I didn't. Anymore, I just simply leave it on anymore...
Dan
Dan
