goducks10 wrote:
Really, the only reason MFG's make the two different types is so RV forums can have countless pages of debate on the subject.
+1, but there are other reasons as well. Filon versus aluminum is easier to deal with in the build process, quicker assembly and less fasteners used versus aluminum. Filon composite looks better initially but like aluminum, the finish will degrade from exposure over time and delamination is always a possibility though not a guarantee so long as the seals and caulk are maintained properly. So long as there is no water intrusion between the walls and the outer skin, it will not delaminate.
Aluminum, on the other hand will corrode just like steel. It oxidizes and will eventually develop holes. Again, that usually occurs when water is present on the backside. Soaked insulation and rotting wood promote electrolysis and the aluminum 'white rusts' away.
It's a toss up. Filon composite looks nicer but needs surface maintenance. Aluminum don't look as nice but still needs surface maintenance.
Really, it's all about manufacturing more than longevity.
