I am new to all of this so if I make some mistakes try not to beat me up on it too much. I am looking at some TT's that have a GVWR under 6000 lbs. I want to pull it with my 2023 Pathfinder Rockcree...
Before you get set on any specifics on trailers, first understand what your Pathfinder can tow. You need to look at payload, that is weight on the ball. That is the important number, how much weight can it safely tow which is commonly called payload. This includes cargo in your tow vehicle. Once you know that, you can look for trailers that meet that standard. Often the 6000 GVWR is an incorrect number.
