alzwakExplorerMay 06, 2016TT tow weight?I have a 23 ft travel trailer (gvw 4360 lbs / gvwr 5500 lbs) I plan on towing it with my 2006 GMC 1/2 ton truck SLT 5.3 Eng. with the towing package, also installed in the truck are the trailer brake ...Show More
Need-A-VacationExplorerMay 07, 2016+1 what Soundguy posted.The GM 6spd/3.42 combo is actually better than the previous gen 4spd/4.10 combo in regard to towing.If you have the 3.73 gearing, should do pretty well overall. If you have the 3.42, it will do it, but may not be as well as you hope.Check you glovebox sticker for a G code and do a search for it. GU6 is a 3.42, GT4 is 3.73, GT5 is the 4.10's.
Related ContentTow weightDry tongue weight versus fully loadedUnderstanding towing weights?Tow RatingsNew to TT - TT Tow Weight Question
