alzwak
May 06, 2016Explorer
TT tow weight?
I have a 23 ft travel trailer (gvw 4360 lbs / gvwr 5500 lbs) I plan on towing it with my 2006 GMC 1/2 ton truck SLT 5.3 Eng. with the towing package, also installed in the truck are the trailer brake ...
4Kellys wrote:
Don't assume it's ok because everybody says so. Do your research, add up your numbers, weigh your truck loaded with everything you normally take with you and a full tank of gas. Subtract that weight from your trucks GVWR and that's your payload. You may be OK but you may not. Don't be one of those RVers out there who don't know or care if they're overloaded!
