Lantley
Oct 15, 2015Nomad
hawkeye-08 wrote:
I would think you can do this, make sure you are prepared to winterize and keep an eye on the weather forecast. Worst case, you winterize and move in with relatives. I just received my cable chains for my tow vehicle yesterday, planning on dry fitting them this weekend and also seeing if the ones I have for trailer fit. I will have chains for truck and trailer when we go out in this fall/winter so I can travel if needed when weather is not perfect.
Our weather is not that severe in Nov./Dec. There will be no need to winterize. Chains are never required in the Balto. Metro area either.
The worse that could happen is a major snowstorm which is possible but not likely that time of year.
The fact that the OP plans to occupy/heat the unit is a big factor as well.
As long as I have my heat on my RV will not freeze in typical Nov. Dec. weather
