dodge guy wrote:
Can you tune a screwdriver or wrench? If so then problem solved!
Are these the screws that attack the lower trim to the trailer?
my thoughts also. if the problem is only loose screws keep it simple in my opnion. life is to short to waste at a dealership or dealing with small warranty claims.
i learned early how to diy most repair and maintenance work on TT. we are currently on our 2nd TT.
just a week ago i found our new TT purchased last november developed a small leak from slide window. my inspection found a window installation "**** eyed" that led to a recent small gap in the foam tape gasket on the frameless window. my walk thru pdi that i did myself missed it. you could not see it unless you totally removed the window treatment/valance and blind. not something you can do to an rv that you don't yet own on a pdi.
i could have taken it to the dealership and it would have been covered under warranty but we probably would have lost at least a month of camping waiting.
google search and youtube taught me how to remove the interior windown trim and correct the bad installation. took me 2 hours but i know its done correctly.
