TomG2
Feb 02, 2014Explorer
Ron Gratz wrote:
.....snip.................
One could argue that the higher GVWR would mean more robust brakes. However, the 2013 F-150 specs page 96 (9 of 15) show that Ford uses the same brakes for 8200# GVWR as for 6450# GVWR.
And, even if brakes do generate greater stopping torque, the stopping force still is limited by friction coefficient and GVW.
Ron
That is interesting (but not surprising) that Ford uses the same brakes on all their F-150's. Compare them to the F-250's and F-350's.
Don't the 3/4 and 1 ton models weigh over 1,000 pounds more than the half ton models, thereby changing the ratio of TV weight to trailer weight? (Towing the same trailer as the half ton) If there is a total failure of the TT brakes, then the TV must stop the whole deal. In which case, I would still rather have brakes designed to stop 9.300 pounds instead of 7,500 pounds. Ever towed on some curvy mountain roads?
