shabr66's avatar
shabr66
Reality Check - Camper Weight
So I have a 2006 Bigfoot 25c9.4 that I carry on a 2005 ford f350 srw truck. The tag on the bigfoot says that it weighs 2400lbs (or there about) and I figure I've got about 1000lbs in the camper. The truck is equipped with firestone air bags and an aftermarket sway bar and seems to handle the weight just fine. However, I have toyo 35x12.5x20 mt's mounted on my stock 20" wheels, and they are only rated at 3200lbs (the tires, not sure about the wheels which are the stock ford harley wheels). I knew the camper caused me to exceed the truck's gvwr and the rear gawr, but I wasn't too concerned because I figured I was only exceeding the rating by a marginal amount; however, I finally scaled the truck this past weekend and the total weight was 13,400lbs and the rear axle weighed 8,400lbs. I was shocked to see that I had my rear tires overloaded by 1 ton. Obviously this is not acceptable so I am now looking to replace my wheels and tires. I really like the Toyo Mt's and noticed that if I go to a 285/75r18 in the same tire, the weight rating goes up to 4,080lb per tire. I would still be over, but I would be much closer. I am however having trouble finding an 18" wheel that is rated for a similar capacity. I know that I could also go the 19.5" route, but I'd really like a tire that is capable off road as I do like to go off the beaten path at times. So, any opinions on the 18" wheels with toyo mt tires vs 19.5's? Are there any decent looking 19.5 wheels out there? Sorry for the long post!
