Ron_Gratz
Feb 02, 2014Explorer
TomG2 wrote:Nope, I'm saying that all F-250/350SRWs use the same brakes. And, previously I said all F-150s use the same brakes.Ron Gratz wrote:Are you saying that the F-250/350 brakes are not more capable than those on the F-150?---
Ford uses the same brakes on all F-250s and F-350SRWs. GVWRs for these trucks range from 9900 to 11500#. Adding nearly 2000# to the GVWR does not gain anything in braking capacity.
I did not say the brakes used on the F-150s are the same as the brakes used on the F-250/350SRWs.
I do hope you realize that the coefficient of friction only comes into play when the tires are skidding.---I do not realize that -- and it is not correct.
The maximum braking force occurs near the point where the tire is just beginning to slip.
Maximum braking force occurs at the optimum slip ratio which usually is in the range of 10-30%.
"Freely rolling" means a slip ratio of zero, and "skidding" usually implies a slip ratio of 100% (wheel has stopped turning).
Ron
