larry_barnhart
Aug 24, 2014Explorer
I almost know nothing about our truck but I do know you can over heat the trannie backing up and dump the fluid on the ground because of the high rear gear ratio so if it is a 4x4 use the low range and you will be good. Check and see if the trannie has a cooler. This would be when towing and backing into a site that is up hill. Have fun
chevman
chevman
44,066 PostsLatest Activity: Jul 25, 2018
