ShinerBock
Nov 13, 2017Explorer
Me Again wrote:
If Ford thought force air was good for the 6.2, they most likely would have done it by now. Ecoboost 6.2!
The importance of factory warranty is becoming more important then ever as these new trucks continue to become more and more complex. So I do not understand why anyone would modify a vehicle in a way that would allow the manufacturer to void the warranty.
I am not sure Ford can turbocharge the 6.2L. Well.... they can, but a lot of the engine would have to be redesigned. The short block is probably good, but many things above that would have to redesigned to reliably handle turbos and direct injection.
Then there is the issue of being no fuel economy benefit. The whole point of the Ecoboost engine is to downsize it to save fuel for those times you don't need all that power. Just slapping turbos to the same size engine will not help them attain the upcoming fuel economy regulations that are coming to the 10k GVWR and up trucks. I can see them using and iron block 5.0L or the 4.8L that they were reportedly working on as an Ecoobost platform for the SD though. Something like that would easily make 420+ hp and 550+ lb-ft.
