2014screw wrote:
pappcam wrote:
2112 wrote:
You are close but doable.
Put a pair of Timbrems on the rear to help with squat and stability.
It's a short trailer so stability shouldn't be much of a concern.
Have your TT and TV tire pressure at maximum as stated on the tire sidewall.
Don't pack too much weight on the rear bunks, as tempting as that may be. That will cause instability as well.
No need for Timbrens. I have a similar TV and my TT is a little heavier and I'm fine and within all my weights. I have an XLT and the payload is 1450 or close to that and it works for us.
The OP will be fine as long as he doesn't throw a bunch of heavy stuff in the box of the truck.
Couple of bikes, spare 20lb propane bottle and a small tank of gas for the generator in the bed of the truck.
I figure my TW (554 Dry) would be roughly 700 lbs with full dual 30lb propane bottles and a 12V battery
But really, seriously, is going over your payload by a few hundred pounds a big deal with these new trucks??
