DrtrashExplorerFeb 05, 2016Tv AnteneaIs it possible to remove without damaging connection for future use? Don't use it and want to remove solar panel shadowing
RoyBExplorer IIIFeb 05, 2016If your antenna looks like this just remove the clips shown here and pull out the bolts. Then lift out the two arms. Then disconnect the RG cable connection. I would cover the Antenna connection with something to keep moisture out of it...Roy Ken
