YC 1 wrote:
Bumpyroad wrote:
doesn't OMNI directional mean semi poor reception in a 360 degree radius?
bumpy
Nope. Omni can even be designed with gain. That said I suspect there is an amplifier inside that round head. Should be close to the performance of the Jack antenna. Only disadvantage is being so low to the roof.
FCC 1st class
Certified ET
Telecommunications Technician
Yes - per the below specs it is amplified. I'm assuming this antenna is doing double duty as the FM radio antenna for the unit. If that's the case and it works, that's one less hole in the roof!
Specially compatible with HDTV of various digital terrestrial signals (DVB-T, ISDB-T, DMB-T/H, ATSC) and DAB/FM radios
Waterproof housing design made of UV resistant material
Built-in high gain and low noise amplier, shielded for minimum interference
The antenna is surface-treated to withstand impacts from all weather conditions
Solid design for strong wind resistance
Receiving range: FM/VHF/UHF
Frequency range: 47-230MHz; 470-862MHz
Gain: 30dB
Dimensions: 190H x 1225W mm
Max. Output level: 110dBV Max
Power supply: DC12V
