Make my own oil bottle from this and heat/pull the tip to make an approx 1/64" dia nozzle. Tube is about 8" long and can reach/poke/etc into spots regular oil cans and sprays can not get to and/or will make a mess
If anyone makes one, be sure to pull the tube all the way out when storing it. Else it will expand from ambient changes to make a mess
Click For Full-Size Image.
Newer ones has a much longer and refined tip...learned HOW2 heat the plastic and pull with needle nose better. The only way to oil the door hinge pin of my Suburban
(edit)...great for firearms. Most oil can/bottle drops are too big/much
