JJBIRISH
Apr 22, 2014Explorer
I have been in several Signature Ultra Lite 8311SS and the all that I have been in had 2 TV’s hanging on both sides of the same wall… one in the Entertainment Center and the other mounted to the same wall facing the Master Bedroom…
I always thought it was the perfect place for 1 TV that swiveled for viewing from either room…
With the aluminum framed laminated outside walls, wall studs may be hard to find… unless the mfg. installed amounting plate behind the wall the only option for a secure mount might be the TV mounted to a backer board mounted to the wall…
As others have already said the best bet is to check with the mfg.…
