Grit dog wrote:
steve-n-vicki wrote:
figure this one out
OEM tires ,2205 max load at 35 psi max pressure, door sticker 35 psi,
replacement tires 2337 max load at 51 psi max pressure , if i run these at 35psi per the door sticker the load chart says 1604 pounds of weight, for me to get back at 2205 load i have to run 48 psi in the tires,
so do i run the truck manufactuers tire pressure of 35 psi or the tire manufctures pressure of 48
Lower profile tire?
What do I win?
The real question is what capacity do you "need" front and rear for a given condition?
Empty driving, must be a smaller,older truck. Even stripper F150s come with 44psi skinny 235/245 wide tires for years now.
1600lb per tire = enough load capacity for any empty rear axle weight on a half ton pickup. Gettin close on big crew cabs with "standard" beds though. I got about that 37 psi cold in my crew cab half ton with a 500lb tool box and it rides like a dream. OE 255 70 17s.
1600lb per tire is a bit light for a newer V8 pickup front tire especially if there's more than 2 doors in the equation.
