blkdodge
May 16, 2017Explorer
TV tires
I currently run Michelin tires but have an issue getting a replacement from Discount Tire here in Phoenix. What would be a equal or better replacement tire? I only get approx 48-40K on these 70k tire...
FishOnOne wrote:Me Again wrote:Cummins12V98 wrote:
"Well that is disappointing to hear about the Defenders. Chris "
Mine are labeled MS2's not Defenders. I know they are supposed to be the same.
Still disappointing on the mileage.
Briddgestone Dueler H/T 685 looks very similar to the Michelins.
I am going to stop at a FS/BS store today and pick their brains a bit on them. 50K mileage warranty seems good.
HEAVY-DUTY STEEL BELTS AND 2-PLY POLYESTER CONSTRUCTION
Engineered for towing and carrying heavy loads
WIDE GROOVES
Push water away from the tire, which helps reduce the risk of hydroplaning
SPECIALLY ENGINEERED TREAD DESIGN
Helps retain traction in snowy conditions to help you power through winter
NEW AND INNOVATIVE TREAD-TO-ROAD CONTACT FOOTPRINT
Allows the tire to adapt to the load and promote even wear
With a 50k mile rating they must be a cheaper tire.
