SoundGuy
Feb 09, 2018Explorer
SoundGuy wrote:
.. replaced my two paralleled group 27 batteries with a pair of golf cart batteries. I immediately noticed several differences. One, anytime I operated a heavy lo:Rad the voltage sagged MUCH more than it did with the old batteries.
2oldman wrote:
For heavier draws, 4 or 6 batteries are much better.
Isn't that self evident? :R The fact remains that whether one uses six 6 volt GC-2s wired in series / parallel or three 12 volt G31s wired in parallel voltage drop under heavy inverter load will be less with the 12 volts than with the 6 volts. The second fact is that by using GC-2s which were specifically designed for golf cart use one is adapting batteries to RV use ... adapting, not using a battery specifically designed for the task at hand. ;)
