Westcoasting
Feb 09, 2018Explorer
SoundGuy wrote:SoundGuy wrote:
.. replaced my two paralleled group 27 batteries with a pair of golf cart batteries. I immediately noticed several differences. One, anytime I operated a heavy lo:Rad the voltage sagged MUCH more than it did with the old batteries.2oldman wrote:
For heavier draws, 4 or 6 batteries are much better.
Isn't that self evident? :R The fact remains that whether one uses six 6 volt GC-2s wired in series / parallel or three 12 volt G31s wired in parallel voltage drop under heavy inverter load will be less with the 12 volts than with the 6 volts. The second fact is that by using GC-2s which were specifically designed for golf cart use one is adapting batteries to RV use ... adapting, not using a battery specifically designed for the task at hand. ;)
What about dry camping for four days... only battery use is lights at night, and the water pump. Do you think two 12v for this application as well? What do you recommend for the best battery to buy?
