Vvvv1010 wrote:
I recently had a 750 amp read on secondary battery and a 440 amp read on the primary battery. I chose to only replace one at Ford dealership that was still under the Motorcraft Tough Max 100 month limited warranty. This is my 7th battery in 6 years.
I made the decision when they both need replacing I will go to a better battery brand. I've been chasing full warranty and limited warranty on the Motorcraft brand every 2 years.
Wow, Texas must be harder on batteries than Pennsylvania winters. I have the exact same truck with the original batteries. (Knock on Wood) :? You might want to have the charging system tested.
