Old-Biscuit
Mar 28, 2021Explorer III
Slides can be partially opened for access to other items/areas as long as you DO NOT use the slide unless FULLY Extended
Rest Areas.....that varies by State
If you see other parked then most likely OK
If you are the only one........hummmmmmmmmmm?
