ford_truck_guy
Aug 14, 2019Nomad
cbwallace wrote:ford truck guy wrote:cbwallace wrote:
It sounds as though the generators are not actually running in parallel for some reason. I have run a 13.5 A/C unit on a single Honda at much lower altitudes but it is about all the generator can handle. I have also tried to do the same at 5,000+ feet and it will not do it. However, I have run 2 Hondas in parallel many times and it will run the microwave, A/C and fridge all at the same time with no problem. The Hondas in parallel should run close to all of the same amenities as a 30A outlet.
^^^ check this.. When I was running the same set up, I was rushed 1 day during set up and I reversed 2 of the 3 cables that run it in parallel.. was not running AC, just everything else, the MAIN genny ran out of fuel while the 2nd was still almost full....All the draw was on 1
I've not managed to do that yet, but always wondered what would happen if you crossed the red and black wires.
yup... It was a cluster that day, but I succeeded in doing that ! Then I pounded in my head - - Red = R = Right.....
