ktmrfs
Aug 14, 2019Explorer III
Tvov wrote:
Do the generators have their "ECO" mode turned OFF? We ran a 13.5 A/C for a weekend using an EU2000 without any problems, but the ECO mode had to be off... which meant it was not quiet.
Yes, we were at sea level, but with the amount of power you are using you should be able to run A/C.
before I installed the micro air easy start, my paralled honda's had to be off the eco mode even when in parallel to start the AC if we were much above sea level or it was quite hot. One generator if lucky would start the AC at sea level if not in eco mode. once started I could go back to eco mode, but then if the AC shut off I had to remember to go back off eco before the AC decided to come back on again.
This was even at sea level, worse at 5,000ft or so.
with the micro air, one honda 2000 in eco mode easily starts the AC even at 6000ft or so, but will soon overload. the honda 2200 is fine for long term starting and running the AC at 7000 ft in eco mode.
