- dodge_guyExplorer IISomething is wrong! 4400 watts of generator should run the AC and other electronics without issue.
What is the voltage before turning on the AC? - wnjjExplorer IIMake sure the fridge isn’t on “auto” and switching to electric. Be sure the water heater electric isn’t on. Also try turning off the breaker to the converter/charger.
- You may need a start cap, replace a defective one, or get an electronic start cap like Micro-Air.
- pianotunaNomad III3% loss of power per 1000 feet. 5280 = nearly 16% loss.
- edekgbExplorer.
EU2200i and EU2000i Parallel Operation
The EU2200i are only compatible with EU2000i or EU2000i Companion models within a specific serial number range:
EAAJ-2017305 through EAAJ-9999999
EACT-1000001 through EACT-9999999
Connecting an EU2200i with an EU2000i or EU2000i Companion that is not within the compatible serial range above may cause a low voltage output, which can damage tools and appliances powered by the generators. Units outside the compatible serial number range should only be paralleled with another EU2000i.
Learn more about paralleling the EU2200i and EU2000i here - edekgbExplorerI thought this initially but after a long conversation with honda - they said these two types will be fine together.
- Home_SkilletExplorer III thought both generators had to be the same size?
