MFL
Jul 24, 2015Nomad II
I use a light coating of Teflon trailer ball lube, works for me. It is not supposed to attract dirt, but will leave a spot on your pants, if you don't watch what you are doing.
I have noticed temps on the heat gun from 90 ish, to 120, depending on outside temps, and if sun is hitting hub. Like mentioned, you want to see hub temps close to the same. The sunny side will likely be 10-20 degrees warmer than the side running in the shade.
Jerry
Jerry
44,066 PostsLatest Activity: Oct 04, 2013
