prichardson
Jun 13, 2016Explorer
After an initial sanitizing, if you use a good municipal water supply for filling your tank you should not need to again unless you take on some questionable water. Black tank sensors are notoriously inaccurate as it is impossible to keep them clean enough to give accurate readings.
44,030 PostsLatest Activity: Feb 04, 2025
