bpounds
Jun 13, 2016Nomad
1. I would just use liquid bleach. I use 1/4 cup per 15 gallons of water. Pour the bleach in, fill with water, run every fixture until you smell a little chlorine. I usually let it sit overnight, then drain the tank.
2. The tank gauges are never accurate, and the black tank is the worst. No point in trying to clean it, it won't last. You will learn to live without it very quickly. Fortunately the black tanks is always the lowest usage by volume, so it never gets full first.
44,030 PostsLatest Activity: Feb 04, 2025
