DE88ROX
Jun 14, 2016Explorer
sac89 wrote:
Two general questions, which I am sure have been discussed if I took the time to search for the answers...
1) What is the easiest way to sanitize the freshwater tank? Bleach and water mixture is recommended by manufacturer, but are there chlorine tabs I can drop in? Also how often should that be done?
2) My black tank indicator is showing 1/4 full when the it should be empty. After dumping, and all the waste is drained, the indicator light still shows 1/4 full. I have one of those internal wand things that is supposed to help flush the system, but the light still shows stuff. Thoughts?
Get yourself some Horst Miracle Probes. I replaced my OEM probes with these and they are very accurate. Never a false reading. Easy to swap out if your under carriage is exposed like mine is.
44,030 PostsLatest Activity: Feb 04, 2025
