Cicch95 wrote:
Looking for something short and fairly lightweight due to the limitations of my TV. 2014 Ram quad cab express. The major limitation is going to be payload. Yellow sticker says 1,390 lbs.
I was wondering for those of you have ever actually weighed your gear. (Net after empty trailer vs full trailer!) What a typical weight is for all the gear usually brought. Obviously, there will be lots of variables but I am trying to get a ballpark!
With limited truck payload capacity your greatest "variable" is how many people in the truck and how much they weigh - which you haven't indicated at all. As far as trailer cargo weight is concerned a lot of us would consider 1000 lbs as a not unreasonable estimate and although the heavier the trailer the greater will be the gross tongue weight whether that "1000 lbs" actually works out to 800 lbs or 1200 lbs isn't directly related to your truck's rather limited payload capacity.
