After 13 years I decided it was time for a newer camper. I want to move my old style Reese dual cam to my new camper. The new camper frame is longer and now my U bolts dont fit. I have checked th...
Get some threaded rod in the proper diameter. heat it and bend them in the proper places to make a new u-bolt. I had to do this with my lower air bag mount that is u-bolted to my spring. I used MAP gas with a torch tip (same as used in soldering copper plumbing) to heat the threaded rod.
